Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Sierra Chapter > Sierra Chapter For Sale
Sierra Chapter For Sale ONLY Local Sale Items here.
Old October 11th, 2010, 21:34
jimbosz07 jimbosz07 is offline
Random but need Chryco 8.25 pinion yoke
Yup, the one of the little pins that holds my driveshaft centered on the yoke broke off and I need a new one. I know this is a pretty simple little part and it would be easy to go to the junkyard to grab one, but I thought I'd see if anyone has a 8.25 sitting around that they wouldn't mind me taking the yoke off. Besides, I can't imagine pulling one at the junkyard without an impact gun.
Thanks
Old October 12th, 2010, 11:08
jeepme's Avatar
jeepme jeepme is offline
Re: Random but need Chryco 8.25 pinion yoke
I have a new one drilled for u bolts that i never used.
Clayton long arm lift, F250 D44 front with RCV shafts, Currie 35 spline 9 inch rear, 37's, ARB's, OBA, Rubi T-case, Accutune Fox shocks, Radesigns manual shifter, yada yada yada.
Old October 12th, 2010, 12:58
Not sure what you mean by drilled for u bolts, but as long as it will fit a stock XJ front shaft then I'm interested
Old October 12th, 2010, 13:19
jeepme's Avatar
instead of using the u joint straps it uses the 1310 u bolts. Much stronger.
http://www.dennysdriveshaft.com/p340...30_series.html
Old October 12th, 2010, 16:21
Letterman's Avatar
Letterman Letterman is offline
Great upgrade, if you snap a bolt off on the trail it can really take a long time to try and get the busted theaded end out. If you snap a u-bolt the broken parts slide right out.
Old October 12th, 2010, 21:43
Sent you a PM jeepme
Rate This Thread:
WTB d44 pinion yoke redneckboarder NAC Classifieds 5 March 9th, 2010 06:48
CHRYCO 8 1/4 RING AND PINION UPGRADE jack96xj Modified Tech Discussion 6 November 17th, 2009 08:56
WTB Pinion Yoke 90XJay NAC Classifieds 1 June 10th, 2009 10:18
WTB - C 8.25 Pinion Yoke gorilla_skater NAC Classifieds 5 June 1st, 2009 11:24
flange yoke connecting DS and pinion yoke Shomsky462 Advanced Fabrication and Engineering 23 May 14th, 2006 18:19
