Purchased a set of blackout LED headlamps for the XJ....and, all looked good, until I noted that, even with the switch in the full-OFF position, the low-beam LEDs still have a fainter/low-output...??
Just to note; there are driving light aux. lamps, on either side of the bank of LEDS, but I did not connect those.
THUS, I can't imagine WHERE the juice powering the low-output for the low-beams described, is coming from.... Off, should be, OFF, one would think.
Any thoughts...??
{Did send a message to the seller, but...in the meantime, I thought I'd see if anyone has any idea....}
Thanks.
Any thoughts...??
Thanks.
