Old December 7th, 2003, 15:58
tommy1102 tommy1102 is offline
Question bigger lift, now what???
right now i am running a 3 inch skyjacker lift with rustys shackles and spacers so i'm up around 4.5 inches of lift. i just bought the RE 4.5 extreme duty leafs and was wondering what else i need once i install them. with my rustys shackle i should get almost 6 inches of lift in the rear and i also have 4.5 colis and 1.75 spacers for the front. i have the tc lowering kit and sye is next on my list, besdies that is there anything else that is needed once i go to that height?? and suggestions would be helpfull. thanks
Old December 8th, 2003, 13:58
jeepme's Avatar
jeepme jeepme is offline
Re: bigger lift, now what???
You will need an adjustable track bar and at least adjustable lower control arms. Some longer shocks would be good also.
Clayton long arm lift, F250 D44 front with RCV shafts, Currie 35 spline 9 inch rear, 37's, ARB's, OBA, Rubi T-case, Accutune Fox shocks, Radesigns manual shifter, yada yada yada.
Old December 8th, 2003, 17:01
juicexj24 juicexj24 is offline
Those RE 4.5 leafs will give you over 6" of lift. That height is for a heavy weighted rear. On mine that are still over 6". For the front your fine. I would get the adjustable trac bar. but put on the leaf springs first and than see where it sits before you do the shackles. Just a thought...Juice
Old December 8th, 2003, 20:03
bottleworks's Avatar
bottleworks bottleworks is offline
Longer Brake lines.
Old March 10th, 2004, 22:55
jlaw3000 jlaw3000 is offline
i second that.. they are a pain in the ass but its worth not having to worry bout it.
Old March 15th, 2004, 01:52
Richdaman's Avatar
Richdaman Richdaman is offline
You might start wanting to think about steering options and support issues. It really is amazing home much you have to start modifying after 4.5 inches ...
Old March 8th, 2005, 06:58
chase chase is offline
how bout another 8 inches?-hah
Old March 9th, 2005, 07:49
generalleexj generalleexj is offline
you said that the SYE was next on your list also ? well if you get this youd also need to invest in a new driveshaft proper for your set up. this can get kindof pricey. i just did the exact thing youve done and swapped all my 3 inch springs for 4.5 with spacers and shackles on top... so now i have roughly a 6" lift. ive previosly installed an adjustable track bar, s/s brake lines, longer lower control arms, and a transfer case drop. im running the stock ds with no sye which i need to get soon, its just that is where the money starts getting high though.
Old March 9th, 2005, 07:53
XJ_ranger's Avatar
XJ_ranger XJ_ranger is offline
Talking Re: bigger lift, now what???
Originally Posted by bottleworks
Longer Brake lines.
x2 easily forgotten about...
Nothing in Moderation . . .. . . . .... . . . . . . . . . . . . . . competitor #91 . . . . . . . . . . . . . . . . . . . . The Ride Racing
Originally Posted by Bryan C. View Post
As if the program is running with some high level of integrity and only the best of the best win.
Old March 9th, 2005, 09:15
Beej's Avatar
Beej Beej is offline
This thread is over a year old. Originally posted: 12-07-2003
Max lift before I have to change contol arms? simonsxj Modified Tech Discussion 15 February 1st, 2004 09:09
Making 36's work on a 4" lift... CheapXJ Modified Tech Discussion 31 December 27th, 2003 19:46
NC: Major parts for a 4-5 inch lift + 5 31" MTRs on 15x8 767s Scriff For Sale: Private Party Only. XJ ITEMS ONLY 12 December 14th, 2003 19:06
how to go bigger dellstopjeep Modified Tech Discussion 15 December 8th, 2003 22:31
Lift on Ebay 96xjeeper For Sale: Private Party Only. XJ ITEMS ONLY 1 December 7th, 2003 21:40
