RWKHausSupply
- yorba linda, Cali
Dana 30 3.73 & UP 30 Spline E - LOCKER
The ELocker’s electromagnetic locking mechanism is the next generation of aftermarket differential technology. Performs as an open differential until you decide that you need more traction. Eaton ELocker is your push button solution to almost any traction problem.
Designed expressly for 4-wheel drive systems to give you the ability to lock or unlock the differentials when necessary. When locked the Eaton ELocker performs as a full locker, capturing 100% of available torque and sending it equally to both ends of the axle.
The ELocker is built with precision-forged gears that are designed to mesh perfectly, providing improved strength and durability over a standard cut gear. Its ease of installation, reliability and push-button activation make ELocker an absolute must for all traction and off-road performance applications.
$725 to your door, for a limited time.
Can also include a set of 30 spline chromoly axles (with spicer ujoints and seals) for 499$ more, that have a limetime warranty.
Email for best service and fast replies,
[email protected]
[email protected]
