Old January 26th, 2009, 13:03
jeepman121's Avatar
jeepman121 jeepman121 is offline
AW4 Solenoids?? NSS??? Both???
So over a YEAR ago after fording through some flood water I had a 5 minute issue where my jeep was starting from a stop in 2nd gear. After turning the key to half position and shifting from P to 1st back and forth it started up and went fine....I noticed in the last month that if I was to downshift the jeep manually lets say at 35 mph, that instead of it dropping into 1st at 25 mph like it should, it would sometimes not hit first untill 15 mph....then I had the 2nd gear start issue again for 5 minutes...and today I was at 35 mph dropped to 1-2 and it actually shifted into 1st (at 35) reved high then went to 2nd, then back to first...I left it in 1st stopped and took off and it shifted into 2nd at like 15 mph (when It should do that dumb redline shift that I hate) tried to drop it back in 1st and it would not go into 1st unless I stopped. turned it off and on and it drove fine. I'm confused.- 95 XJ 4.0 AX4 168,000
Old January 26th, 2009, 14:12
jeepman121's Avatar
Re: AW4 Solenoids?? NSS??? Both???
Is it a PITA to do the solenoids...I saw a quick fix for the NSS in JP magazine. If that's what it is....
Old January 27th, 2009, 08:07
jeepman121's Avatar
*bump* .............?????
Old January 29th, 2009, 07:54
jeepman121's Avatar
nothing??
Old January 29th, 2009, 08:21
winterbeater's Avatar
winterbeater winterbeater is offline
I believe that the NSS is just for starting and does not affect the transmission shifting. Weird shifting is often caused by the TPS. You could check that with an analog voltmeter. I'm not sure what the voltage range should be on your 95 but it needs to be a smoothe transition from closed throttle to wide open with no dead spots. I'm sure you could find the actual values for yours by searching threads.
Old January 29th, 2009, 10:11
joe_peters joe_peters is offline
x2., NSS does not effect shifting.
Old January 29th, 2009, 10:15
rogersjeep's Avatar
rogersjeep rogersjeep is offline
Pull your trans cover and remove and check the soleniods.
I checked mine by just adding power from the batt. And if it clicks its good. No click its bad. Replace as needed.
Old January 29th, 2009, 13:19
searchingforXJ searchingforXJ is offline
You don't need to do all that to test the solenoids. All you need is a ohm-meter to check them from inside the jeep. Find the harness that plugs into the TCM and you check a few wires there, I did it this past summer on my brothers jeep. I'll see if I can find the wiring diagram.
Edit: Sorry, I meant TCU.
Old January 29th, 2009, 13:22
jeepman121's Avatar
It only does it randomly...I'm wondering if they would still click even though they are bad.
Old January 29th, 2009, 13:32
Random = wires/connections. Have you cleaned the contacts on the plugs going to the solenoids. At least unplug and plug them several times to scrape the contact surfaces of the plugs.
Old January 29th, 2009, 13:35
In my brothers Jeep he would lose 2nd & 3rd randomly for a few weeks before they disappeared for good.
Old January 29th, 2009, 13:42
4LowandGo's Avatar
4LowandGo 4LowandGo is offline
Mine is doing the same thing as the first post states. Please PM me with instructions on checking the TCU harness with an Ohm-meter.
I have a '92 HO with an AW4.
Old January 29th, 2009, 13:49
Every time I try to post with a link the post disappears, what's up with that?
Old January 29th, 2009, 20:27
copy shortcut, open thread, paste.
http://www.naxja.org/forum/showthread.php?t=982600
Old January 29th, 2009, 20:34
Here it is. Just take out the space. I tried to post it once, and the post didn't appear. I then edited a post to include it, and the post was removed instantly.
http://www.great lakesxj.com/tech/TCU4.jpg
WTB: AW4 solenoids bigalpha Wanted: Private Party Only 0 October 5th, 2008 21:42
AW4 Solenoids Twistedlink OEM Tech Discussion 2 August 9th, 2008 08:39
AW4 Solenoids Zick OEM Tech Discussion 15 July 21st, 2007 10:58
AW4 solenoids TwistedSymphony OEM Tech Discussion 26 June 23rd, 2007 10:28
aw4 solenoids jeffnun OEM Tech Discussion 3 June 14th, 2005 08:43
