Old May 4th, 2021, 09:56
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Re: Greaseable Shackle Bolts
On OEM bushings the center sleeve is not supposed to move, it's even bonded to it.
I think I think you've misunderstood the question I asked. Let me restate it to better explain where my head is at.
As the suspension compresses, the leaf spring flattens and "gets longer", causing the shackle to swing toward the rear bumper. This imparts some degree of rotational force onto the bushing and bolt in that eye of the spring. When the suspension droops, the spring "shortens" again and the shackle swings back toward the front of the vehicle
Unrelieved, this will cause the bushing to "wind up" like a torsion spring, which I assume is not an intended effect of cycling the suspension (in the same way that rotational stresses build up in a 231-equipped jeep operated in 4Hi on pavement where the wheels cannot slip).
Assuming that this "windup" effect is not part of the suspension design, there are only two ways that I can see to relieve it - either the bushing must rotate within the spring eye, or the bushing must rotate on the bolt.
Since the eyes in leaf packs do not normally come with grease fittings in them, I must therefore assume that the intention is for the bushing to be able to rotate freely on the bolt holding it to the shackle. The bolts we've been discussing in this thread support this conclusion, as they clearly are meant to supply lubrication to the space between the bolt and the inside of the sleeve.
With a urethane bushing, the sleeve looks (to my eye based on pictures) to have been made via extrusion - no seam, and perfectly cylindrical. Slipped onto a bolt in the hand, it seems like it should rotate quite freely. Not having handled any of this type, I don't know if the sleeves rotate in the urethane or not.
The sleeves in the OEM rubber bushings, based on the Clevites I used when I replaced my leaf packs several years ago, looked different. They appear to have been made by taking a flat piece of metal and bending it around a template - I could see where the two "sides" of that piece were brought together. When I slid a bolt into those bushings, I basically could not rotate the bushing at all on the bolt. This would explain why maxbraketorque reports delamination in his rubber bushings - the formed sleeves simply cannot rotate freely like the extruded ones found in urethane can.
My question was whether the binding of the bolt in the formed sleeves of OEM-style rubber bushings is supposed to occur, or if it's a sign of a manufacturing issue and they are supposed to spin freely as well.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old May 4th, 2021, 10:51
maxbraketorque maxbraketorque is offline
Rubber bushings are bonded to the inner and outer sleeves, and therefore, the rubber is meant to twist / wind up like a torsion spring. It is bonded to prevent the leaf spring from sliding sideways on the sleeve or on the spring. Urethane bushings are fundamentally different in that the bushing spins on the sleeve. To prevent the spring from moving sideways, a lip is added to each side of the bushing that acts as meat between the spring and the shackle.
Old May 4th, 2021, 10:58
RCP Phx RCP Phx is offline
I can only "assume" but the FSM states to lower the weight onto the vehicle before tightening the bolts, and with really high torque values(they vary) there is not much chance they intended on the sleeve being able to rotate.
Old May 4th, 2021, 20:55
NOTNSUV's Avatar
NOTNSUV NOTNSUV is offline
You Guys ROCK!
.. and Mike at MORE told me that he recommends only 35# torque on spring bolts SO they
WILL spin (talking TJ but shouldn't matter). I mentioned that OEM spec is 85# (or so) and he thought that would defeat the intended function.
I'm a 'Do-it-Twice' kinda guy.. or..
Cross thread's better than 2 lock-washers
1999 XJ Sport 4.0L Black
Old May 5th, 2021, 07:51
That's horrible advice. Most of the OEM bushings I seen have a serrated edge on the sleeves that would cut into the XJ uni-body in a heartbeat!
Old May 5th, 2021, 08:29
NOTNSUV's Avatar
You Guys ROCK!
I always hesitate to stray from factory specs and this seemed to be an odd one.
Old May 5th, 2021, 09:27
NAXJA Member #920
thanks for clarifying. I learned something today.
Tha
1984 Dodge Omni
Greaseable or non-greaseable axle shaft u-joints? Jeepguy03 Modified Tech Discussion 19 February 17th, 2013 16:16
Greaseable or Non-Greaseable sway bar bushings? Paintballpsyco2369 Modified Tech Discussion 11 July 14th, 2011 11:08
how important is it to grease a greaseable shackle? philip_g Modified Tech Discussion 6 July 6th, 2007 20:00
U-joint replacment, greaseable or non greaseable? Spanky414 OEM Tech Discussion 7 August 26th, 2006 12:02
greaseable vs. non-greaseable U-joints AJPulley OEM Tech Discussion 10 May 7th, 2006 23:44
