Old May 3rd, 2021, 08:44
NOTNSUV's Avatar
NOTNSUV NOTNSUV is offline
You Guys ROCK!
CAD and Stiffeners
Yup, lots of threads on both topics but not finding specific answer.
About to install drop brackets with approx 4.5" lift (up from 3.5"). I have JKS adjustable upper and lower control arms (short). Also considering frame stiffeners, yet to be chosen from some recommended here. Not going long arms.
Having never seen either CAD or stiffies installed curious whether the stiffies need to go on prior to the CAD? CAD are bolt-on?
Considering whether to bother with stiffeners. Some off camber and rock stuff but 90% 'trail'. How much reinforcement do winch bumper, hd rear bumper, gas tank skid, steering support, transfer case skid, and rock sliders contribute?
Thanks.
I'm a 'Do-it-Twice' kinda guy.. or..
Cross thread's better than 2 lock-washers
1999 XJ Sport 4.0L Black
Old May 3rd, 2021, 09:46
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Re: CAD and Stiffeners
I've read the instructions on two sets of the CAD brackets - RE and RCX. You do have to drill into the bottom of the frame rails as part of bolting on reinforcement brackets.
I' that bolt to the rear face of the new LCA pocket and extend back along the framed The rest of the install all seems to be within the OEM control arm pockets. tend to think that unless the stiffeners wrap around the bottom of the rails they're not going to interfere with each other, but have that's just a guess.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old May 3rd, 2021, 11:01
VAhasnoWAVES VAhasnoWAVES is offline
if you have the ability to do the stiffeners yourself then the drop brackets can be easily modified for the stiffeners. personally the self tapers that RE and RCX use into the frame rail arent really meant for abuse. i would stitch weld the brace to the stiffener and drop bracket in a manner that can be cut away easily if you ever decide to change things.
much stronger that way.
Old May 3rd, 2021, 15:08
NOTNSUV's Avatar
You Guys ROCK!
On that note, it sounds like the CAD could be installed, bolts only/no welds, then removed if I decided on stiffies at a later date. I get why the stitch weld for sure.
Thanks.
Old May 3rd, 2021, 15:25
denverd1 denverd1 is offline
drops first, then cut away the stiffener section you don't need.
Old May 3rd, 2021, 18:18
NOTNSUV's Avatar
You Guys ROCK!
I like that answer.
Thinking IRO since they seem well liked around here. Have their 3.5" leaf springs with add-a-leaf coming Thursday.
Old May 4th, 2021, 07:22
Originally Posted by NOTNSUV View Post
I like that answer.
drop first, remove when its time to stiffen.
ultimately the stiffeners is what you want the braces tied too... trying to key the stiffener into the bracket is going to be a lot more work than just dropping the bracket for the stiffener install and putting it back later.
Old May 4th, 2021, 09:15
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
CAD and Stiffeners
I had both. Drops first. Added the stiffeners later and just drilled or elongated the necessary holes to bolt the drops back on. Wasn’t that hard really.
Old May 4th, 2021, 17:04
Evan03 Evan03 is offline
CAD and Stiffeners
Ohh shit.
Old May 4th, 2021, 20:49
NOTNSUV's Avatar
You Guys ROCK!
Originally Posted by Evan03 View Post
Ohh shit.
Ya, there's that..
Old May 4th, 2021, 23:11
It looked broken but I see that it's not now. Looks good the benefit far out way the cons
Old May 6th, 2021, 08:00
Black1990jeep Black1990jeep is offline
i got drop brackets, and will be adding stiffeners. drop brackers will be attached to the stiffener.
stiffeners BRIANHO13 Vendor Advertisements 2 January 16th, 2017 04:39
TnT mid stiffeners RoyalXJ NAC Classifieds 4 April 22nd, 2016 13:58
Stiffeners 47gmhracer JeepSpeed, Prerunner and Competition Tech Forum 21 November 17th, 2009 10:45
Stiffeners fdsa487 Modified Tech Discussion 3 April 27th, 2006 19:06
