Stage 8s not doing their job
XJLI
Long Island, NY
Drivers front was making bearing noises, pulled the hub apart to find this:
I had a problem with the original locking nuts not staying in place, now the stage 8s aren't. Bad spindle? Should I dremel the groove down more? Burn the jeep down?
It sounds like a bad spindle. Probably had some OEM stuff come loose in the past and damage the lip of the groove.
You need a new spindle brother. Looks like the Stage 8s did their job. Kept your wheel on.
