Getting ready to change universals
TDoggs
Indianapolis
I figure I might as well reset everything in the front end.
I do have a question though. In slow sweeping turns. To the right at highway speeds, I can feel the old wobble trying to start.
As soon as I straighten out, it stops. Since the ball joints were only replaced on one side, could hat be the problem?
I've found that when I get a new XJ it's worth it to change all universals, ball joints, control arms, steering tie rod ends and the track bar. It's a bit of cash up front, but once you've got it all apart it goes pretty easily. Last one I went over had 92K on it, I drove it without issues to 220K.
Agreed! And I’m probably already 3/4 of the way there!
I want to remove the 4wd drive shaft and drive the Jeep to see if that's what's causing the "rumble" I feel on the highway (it goes away when I engage the 4wd)
Is it safe to do so?
If you remove front driveshaft do not engage 4wd you can remove rear driveshaft and drive it in 4wd
