I'm replacing the factory trans mount with a Daystar poly mount. Does anyone know if I reuse any of the original steel portion of the factory mount when installing the Daystar mount?
2001, 4.0, AW4, NP231
Daystar makes two different mounts, an 1.5" (actually 1.75") and a 3". It says that the 1.5" is for the 2000 and 2001, but I looked at my exsisting mount and it looks taller than that. I'm not working on it until tomorrow, but I think it will need the 3" mount.
The way it was explained to me was the determining factor was the exhaust hanger. If the exhaust hanger was part of the transmission adapter plate you need the 3".
This Daystar mount isn't correct and I can't find a factory replacement trans mount anywhere. Does anyone know why the mount is different on the 2000-2001's? I checked Autozone, Advanced, NAPA, Rockauto.
And Joe, yours is a manual trans so the mount would be different.
so does anyone know what poly trans mount to order?? I have a 2000, and am about to upgrade to a TNT full bellypan, so I figure I should change the mount while im under there.
