OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Replacing Power Window Motor, Rear Door Driver's Side
Is there any way to remove & replace the power window motor, with out pulling the whole regulator assembly out. I tried for a short time, but it seems the screws are too long to do it.
Thanks Bill |
#2
Re: Replacing Power Window Motor, Rear Door Driver's Side
you would have to dissasemble the window motor to detach it from the regulator
Thread Tools | |
Display Modes | |
Power locks stuck or stopped working on driver's side door | jeeperguy21 | OEM Tech Discussion | 5 | January 2nd, 2008 15:24 |
Driver's Side Power Window Problem | Fatalfunnel | OEM Tech Discussion | 16 | November 4th, 2006 13:55 |
Wanted: Driver's side power door lock switch - 87 laredo | NotMatt | Wanted: Private Party Only | 2 | July 28th, 2004 07:42 |
Replacing Power window motor on a 86 XJ | Frank G | OEM Tech Discussion | 5 | June 28th, 2003 00:13 |
