Old May 11th, 2009, 15:09
89xjgrey's Avatar
89xjgrey 89xjgrey is offline
Steering stabalizer on WJ knuckle swap...?
Well I don't like the lack of clearance between the tie rod and steering stabalizer on my XJ with WJ knuckles, JKS tie rod/drag link, flip inserts, and WJ rod ends. I'm wondering if anyone has run their steering damper from the passanger side frame down to the drag link, as opposed to the stock location up to the drag link... Pics would be nice also... Thanks.
Old May 12th, 2009, 12:23
89xjgrey's Avatar
Re: Steering stabalizer on WJ knuckle swap...?
Ok, so I gave it a shot. I haven't articulated with the setup yet to check for clearances, but it might just work...
So let me know what you think...yay or nay...
Centered
Full Left Turn
Full Right Turn
Old May 12th, 2009, 14:02
gorman's Avatar
gorman gorman is offline
I've mounted mine on the tierod - okay, mine is a RHD which gives me space for the damper on the right hand side away from the pumpkin.
Old May 12th, 2009, 14:29
89xjgrey's Avatar
That looks good, but unforunately my drag link goes the opposite way of yours. Very little clearance to mount the damper between the tie rod and draglink on mine.
Old May 14th, 2009, 11:59
Senior_XJ Senior_XJ is offline
Question Re: Steering stabalizer on WJ knuckle swap...?
Why are u guys running stablizers on aftermarket steering setups??
They shouldnt be needed hence the upgrade! ((just curious))
Old May 14th, 2009, 12:16
POLAR_JEEP_04's Avatar
POLAR_JEEP_04 POLAR_JEEP_04 is offline
NAXJA Member #2130
why are they not needed?
Originally Posted by XJ&CHZ4ME View Post
Some see this as a silly online jeep club.........we are more than that, we are like family.
Buy from sponsors to support those who support our club!
http://sponsorship.naxja.org/
Join ... http://www.naxja.org/html/membership_faq.htm
Old May 14th, 2009, 13:11
Spent the money on a steering box brace and or the re-enforcement plates.
Its no big deal, just wanted to see what ur answer would be.
Old May 14th, 2009, 13:14
94xjstud 94xjstud is offline
A properly set up steering doesn't need, this is because the steering stablizer is basically there not hide/mask/comfort problems, there is no real need. I haven't run one in almost a year and I have no vibes or wobble
Old May 14th, 2009, 13:26
jdbwrx jdbwrx is offline
I didn't need one on mine, but figured I would dot the i's and cross the t's and just put everythng on. I welded a plate in between my track bar mount and my upper control arm mount and mounted one end of the stabilizer there and use a tube clamp on the other side.
So far the only thing that sucks is having to take the clamp off the tie rod to adjust the toe. It clears the diff fine though.
Old May 14th, 2009, 22:28
jwtrapper's Avatar
jwtrapper jwtrapper is offline
I don't run one on my wj setup. With a proper alignment and caster set to around 6* you should not have any problems.
Old May 15th, 2009, 00:39
gorman's Avatar
When I did my WJ setup I installed everything new and had the alignment done properly, yet I still had major death wobble. Fitted my steering damper back and it was sorted...only to find out last weekend that it's actually still there, just a little subdued. I got death wobble, but with the steering damper fitted it sorted itself out much quicker than otherwise. I still have my control arm angles to fix (will be installing RCX drop brackets), once that is done, I'll try it again without steering damper, but I prefer the peace of mind having the damper in place.
Old May 15th, 2009, 10:24
jwtrapper's Avatar
The steering damper did not fix anything, if you have death wobble then something else it to blame for that. The steering damper is just a bandaid to hide the real issue. You need to check your trackbar and make sure they did a real alignment and not just adjust the toe. Find your print out and make sure they adjusted your caster also. You don't need the steering damper on a good high steer setup.
Old May 15th, 2009, 12:02
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
I personally don't run one, I am building one simply for reducing caster related steering on uneven surfaces. My rig spends a lot of time on the street, and the SS simply makes it safer at high speeds.
If your running one for death wobble, your running it for the wrong reasons.
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Old May 15th, 2009, 12:36
jeeperjohn's Avatar
jeeperjohn jeeperjohn is offline
Originally Posted by jdbwrx View Post
Where did you get that mounting clamp? That's very cool.
Old May 15th, 2009, 13:42
gorman's Avatar
My caster is around 5.5 deg, which is fine and with the HP D30, no vibrations at 6" lift. On the alignment machine they've set everything to be in the centre of the spec range, but I'm not so sure in terms of toe if one should stick to the stock settings or set it differently to cope for large heavy 33" wheels etc. Saying that, I think the major reason for my death wobble was the extreme angles of the lower control arms . I hope the drop brackets will solve those issues nicely.
Help! steering stabalizer TritonXJ Modified Tech Discussion 11 May 23rd, 2008 08:19
steering stabalizer doubleup87 OEM Tech Discussion 11 May 31st, 2007 13:25
steering stabalizer websterky OEM Tech Discussion 5 December 21st, 2006 05:57
No stock steering stabalizer 1985xjlaredo OEM Tech Discussion 1 November 5th, 2006 11:53
Steering Stabalizer Wondo Modified Tech Discussion 8 January 30th, 2005 10:06
