Old December 11th, 2017, 17:29
cody4359 cody4359 is offline
Borla pro xs
ive googled youtubed, and searched without much luck. is anybody running a borla pro xs muffler? I have a flowmaster delta 50 series now and I've finally had enough of the drone and tinnie sound. of the few videos I've found people tend to set the camera under the tailpipe in the garage lol
Old December 11th, 2017, 17:50
ehall's Avatar
ehall ehall is offline
Re: Borla pro xs
I have it, very pleased. Hear it when I step into the pedal but cruising on the highway the MTs drown it out
my '91 beater rebuild
Old December 11th, 2017, 18:04
Borla pro xs
any chance you could put up a video? where I park my jeep it's between my house and garage, and when it's idling it reverberates thru the house and I'm sure the one neighbors I like don't enjoy it, also when in 1st/2nd and going up a hill in the upper rpms it's just annoying.
I have a stock 99 that I'm fixing up and I prefer the stock sound to the flowmaster. I'm after a stock/"touring" sound now that I'm getting older
Old December 11th, 2017, 18:33
ehall's Avatar
Re: Borla pro xs
Here are a couple of clips
Can barely hear it crawling / low RPMs
Into it more here, comes alive as you get into it. But its not loud, compared to the water splashing.
Old December 11th, 2017, 18:47
macgyver_7_6 macgyver_7_6 is offline
Re: Borla pro xs
I have one also. Sounds stock at hwy speeds....growls at low rpms.
A slight bit more aggressive than I wanted at age 47...but nice.
Old December 11th, 2017, 19:19
Borla pro xs
Cool thanks. with headphones in, it sounds a bit louder then what I'm after but it's hard to get the true feel of what it sounds like when your not in person. I've always wanted borla, but I've found a few videos of dynomax super turbo mufflers that sound fairly close to stock... decisions decisions
Old December 11th, 2017, 19:32
Borla pro xs
this sounds pretty good to me with skull candy headphones, would you say the borla is a bit more boomy or louder than the dynomax?
https://youtu.be/KLUoLSVkAuU
Old December 12th, 2017, 17:42
ehall's Avatar
Re: Borla pro xs
Those sound about the same in the back-to-back comparisons, dynomax quieter at idle and a little more throaty. Borla is about the same.
Old December 13th, 2017, 07:13
burntkat burntkat is offline
NAXJA Member #1145
Re: Borla pro xs
I'm in the same boat as you folks. I've always run Dynomax Super Turbo mufflers as I'm not a fan of loud vehicles- there's no excuse for a performance vehicle to be loud. It's all a matter of "small d**k syndrome".
I have a 90 that needs a muffler (the stock has a fist sized hole in it), and my son's 97 is going to before much longer. Dynomax Super Turbo is getting put into each.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old December 13th, 2017, 19:54
trippled trippled is offline
Re: Borla pro xs
Whoa whoa whoa. We younger people call that "old man hatin on the kids!"
I had a drone-a-max. Turbo, ultra flow, they drone like hell. I've found tail pipe exit location also plays a big role in sound in the cab. Run it all the way back and it helps with the sound.
Old December 14th, 2017, 06:36
NAXJA Member #1145
Re: Borla pro xs
Yeah, well without us old f&cks, there wouldn't be any of you young bucks.
Not sure what you did wrong with your Super Turbo. So long as the exhaust is complete stem to stern, I don't get drone out of them. It only makes sense if you exit under the body you'll get resonance... but more importantly you'll also be breathing exhaust.
Old December 14th, 2017, 10:21
Trouble Trouble is offline
Re: Borla pro xs
I got old a few years ago and put a magnaflow SS on and ran the tail pipe back to the bumper. Very quiet which helps on a 3 hour commute. My tires are louder than the exhaust. I put in the largest low profile muffler as i could fit. 2.5" then tapered down to 2.25" tail pipe as that was the only thing premade that i could get that day. I know magnaflow offers a kit with he 2.5" tail pipe.
Old December 14th, 2017, 14:13
techno1154's Avatar
techno1154 techno1154 is offline
Re: Borla pro xs
Good to know someone else did what I did.
I started with a Flow Master 50 series with 2.5" all the way back and out the tail pipe. This thing droned so bad I was afraid to drive into certain areas in Fort Lauderdale FL where there is noise pollution (so to speak) law. i.e. if the vehicle is perceived by the police as being too loud, they could do an inspection of the exhaust on the spot. If it is not an OEM unit, they could cite you for being too loud.
Mind you, the speed limit in these areas were 35 and 40 mph where the AW4 remained in 3rd gear. Not to mention the fact that my ears got tired of that real fast. The solution? Cut the last 18" off the tail pipe and replace it with the tail piece form the OEM exhaust pipe. Co-incidentally, at the low RPM's at which I drive, the 4.0L lost some low end grunt which was restored by retro fitting the OEM tail pipe which increased the back pressure and exhaust flow.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old December 26th, 2017, 14:55
Borla pro xs
ended up being cheap and putting on a resonator. quieted it down about 5db, not as quiet as I'd like but I'm going to start sound deadning soon
Old December 27th, 2017, 07:20
Re: Borla pro xs
What did you end up going with? Or are you saying you put off the muffler for now by going with the resonator?
After I posted a couple weeks a go, I payed more attention to the sound. I don't mind the Borla at all. Perfectly content with it at the "ripe ol age" of 47! More of a loud "hum" than annoying loud exhaust. Kinda purrs at idle.
I fabbed the downpipe myself out of mandrel bends(2.25in I believe)...then into 2.5 inch hi-flow magnaflow converter...2.5inch to Borla muffler. Haven't done my own tailpipe yet, so it is the oem. Very happy.
borla cat-back jsk2052 For Sale: Private Party Only. XJ ITEMS ONLY 7 December 18th, 2006 15:27
Banks vs. Borla Jeff-97XJ Modified Tech Discussion 10 August 9th, 2005 19:35
banks vs. borla (again) hoytinak Modified Tech Discussion 9 March 19th, 2005 10:07
Borla? DjXj Jeep Street and Performance 6 April 16th, 2004 11:38
Borla LiquidOps Modified Tech Discussion 24 September 15th, 2003 17:26
