Old October 20th, 2005, 08:26
jp's xj jp's xj is offline
Question 98 Cherokee gas line pressure
I have been having the same problem many others have had with cold starts. Engine turns over for 6-8 seconds then finally starts. Only happens when sits for a long period like overnight. Just changed the fuel filter/regulator and that helped, but still happens intermitantly. Trying to figure out where a possible leak off of pressure could be coming from, changed the gas cap, checked lines. Could this be a leaking fuel injector?? How would I check something like this?? I don't see anything in my manual about a check valve in the fuel sending unit, which is something else I was thinking could be a problem. Any other ideas??
Old October 20th, 2005, 08:35
LazarusMJ's Avatar
LazarusMJ LazarusMJ is offline
Re: 98 Cherokee gas line pressure
I haven't seen a 4.0 that hasn't had this problem. In my opinion it is just backfeeding to the tank, like you said. A check valve might fix it but I have learned to live with it. If yours has the vacuum operated fuel pressure regulator like my '88 (not too familiar with newer 4.0s) it will take a while to start after sitting over night because even though the fuel pump pressurizes the line when you turn the key, the fuel rail still needs to be pressurized once vacuum opens the regulator.
Old October 20th, 2005, 08:38
langer1's Avatar
langer1 langer1 is offline
You would have to connect a pressure gauge to the test port and see if it's leaking down.
Old October 20th, 2005, 08:42
How would I determine exactly where it is leaking down??? The pressure gauge will tell me if it is or not, but doesn't say where.
Old October 20th, 2005, 09:20
langer1's Avatar
If it's leaking down then you need to block the line back to the tank to tell where the leak is. Injectors need to be tested one at a time with a hand pump.
Old October 20th, 2005, 09:31
Sounds like a lot of work, do you know if there is indeed a check valve in the fuel sending unit for this year ? (it has the serviceable fuel filter / regulator on top of the tank) If I pull each injector and test them, do I have to replace all the o-rings?
Old October 20th, 2005, 09:40
langer1's Avatar
Every fuel pump has a check valve. Always replace the 0-rings.
Old October 20th, 2005, 09:59
Do you know If I can replace just the pump itself, or do I have to replace the whole fuel sending unit?
Old October 20th, 2005, 10:02
langer1's Avatar
You should be able to get either.
Rustys Brake line extension Pogiboy Modified Tech Discussion 7 October 2nd, 2005 12:45
Synthetic vs Steel winch line OverlandZJ Non-Tech / Off Topic 1 March 27th, 2005 11:09
lower pressure ac line jimmy forbes OEM Tech Discussion 2 June 21st, 2003 20:38
How to Tell which Tranny Cooler Line is the Pressure??? eric91xj OEM Tech Discussion 1 June 6th, 2003 10:42
Clutch M/C & line - plastic to metal conversion on a '92 4.0? Mike in NJ Modified Tech Discussion 16 June 3rd, 2003 14:04
