Old December 24th, 2017, 15:54
Crist Clapper Crist Clapper is offline
Re: BUILD: My 1987 "Wagoneer" XJ Limited
Originally Posted by BALTANAKT View Post
Couple Qs:
1-How much work is it to pull out the entire carpet set? Any idea on hours?
2-Whats the process for removing the steel sliders on the cargo carpet?
Trying to restore an xj as well. Keep up the good work.
Removing the carpet is kind-of like painting... It's all in the prep-work! After removing the seats, console, trim, etc., ... The carpet comes-up rather easily... Maybe an hour?
About the cargo-strips... Maybe you already know this... But they simply have spikes that press/pinch into the carpet to hold them in place. I will not be re-installing mine the same way... Will post more information on this later.
Old December 24th, 2017, 16:00
Originally Posted by Ecomike View Post
I would have fixed the gap with duct tape, or Pucky, LOL.
Old December 24th, 2017, 16:15
If you run across the three OEM roof guards that are mounted on the roof between the roof luggage rails, I need a set with the fittings fast.
My roof is rusting, and the bolt holes there started leaking
So I need to replace them, sand and paint the roof fast.
What type do your have? Chrome end-caps?
Old December 25th, 2017, 06:22
BenWheelin BenWheelin is offline
I sold one of those rear air deflectors as a package deal with a fancy JC Whitney style brush guard and rocker rails for next to nothing and was glad to be rid of it all. It was probably all dealer add on. I ran it for about a year and never noticed it to serve any particular purpose, hope that guy finds someone who really wants it someday.
Super clean build.
Old December 25th, 2017, 09:54
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Its the three strips in the middle of the roof that run front to rear. They protect the roof paint from luggage. They were chrome with a black rubber insert top side. The screws went directly into the roof with steel screws. They rusted, and rain got under them and ate a hidden hole in the roof. 2, 1/2" holes by the time I figured it out. Prior owner had caulked the early holes and bottom of the runners, and put the runners back on. I was shocked the screws were steel and directly screwed into the roof.
Looks like they call them skid strips?
https://www.moparpartssource.com/p/J...SABEgL0vfD_BwE
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old December 25th, 2017, 10:06
Ecomike's Avatar
NAXJA# 2091
Looks like went to stick on on 1990, 87-89 is NLA
https://www.jeeppartsoverstock.com/a.../000019BP.html
Old December 25th, 2017, 13:49
Roof Luggage Rack
To start... Here is the parts list:
Old December 31st, 2017, 17:23
Carpet Installation - Looks are deceiving... Took more time
Eighteen hours later... I'm close to being done. Best lesson learned was… Fit the wheel-wells first. It became obvious that since the carpet started flat… Then molded… The widest “fitted” width are the wheel-wells. Once I figured this out… The nip/tuck began! By far I spent the most time fitting around the spare-tire hardware… As it seems the carpet was molded without this in mind.
Old January 1st, 2018, 19:39
TDoggs's Avatar
TDoggs TDoggs is offline
Dang! That Jeep brings back memories!
My uncle had one. I remember riding in the back with my brothers and getting back-handed by my dad for passing wind............
Old January 2nd, 2018, 17:26
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
Now I miss Buster.
reminds me of when I first bought him. His carpet was immaculate (until my kids).
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Old January 5th, 2018, 16:48
Not for the purest...
If you're a purest... Skip this update! lol
The cargo-strips are ready to re-install... But how to-do?
When I had the chrome polished... I had three holes punched in each piece.
My plan, although not tested, is to lay a piece of Masonite under the carpet and attached the cargo-strips to it.
Stay-tuned!
Old January 8th, 2018, 17:07
Seat-belts
Sent out the set to be re-webbed... Looks good to me!
Old January 8th, 2018, 18:40
four_shot's Avatar
How 'bout it Gonzo
Did you have any problem with the buckles themselves coming apart?
4shot
Old January 8th, 2018, 19:22
Ronbo's Avatar
Ronbo Ronbo is offline
Re: Seat-belts
Might I ask who did the work?
Old January 9th, 2018, 08:31
I didn't. But I can see how it could easily happen.
XJ: 1987 Wagoneer Limited Or? Windshield trim? Crist Clapper Wanted: Private Party Only 5 November 13th, 2012 16:41
1987 Wagoneer XJ Limited - Trim color? Crist Clapper OEM Tech Discussion 5 July 15th, 2012 16:11
Parting out: 1987 Wagoneer Limited YELLAHEEP For Sale: Private Party Only. XJ ITEMS ONLY 8 June 25th, 2007 22:55
Parting out 1990 XJ "Wagoneer" Limited XJ&CHZ4ME For Sale: Private Party Only. XJ ITEMS ONLY 14 December 16th, 2006 22:19
1987 XJ Wagoneer 6.5" Lift on 35`s + Extras Fairmonco For Sale: Private Party Only. XJ ITEMS ONLY 12 September 15th, 2006 15:37
