Old November 15th, 2017, 06:19
Crist Clapper Crist Clapper is offline
Re: BUILD: My 1987 "Wagoneer" XJ Limited
Originally Posted by Jeep Driver View Post
Crist, I would like to know the value of the NOS console.
Have you found more than one?
As for consoles... I only know of the one I purchased. Value is determined on the old supply/demand thing. I purchased mine on eBay. Often on eBay there will be NOS console piece-parts such as the base, insert, latch, and arm-pad. If you add-up all the piece-parts... A complete console may be a better deal.
Old November 15th, 2017, 18:57
jpk's Avatar
jpk jpk is offline
Re: NOS Stuff
Originally Posted by Crist Clapper View Post
Fall is nearing and I hope to re-start this project soon. In the meantime... I have collected two additional NOS parts:
Center-floor-console:
Rear-cargo-cover:
Hi. I have a 96 Country and I also have all the hardware to mount my OEM cargo cover. The problem is I need a diagram on how to mount the hardware. I see in your photo your OEM cargo cover has a set of instructions. Would it be possible for you to scan them and email them to me? I would really appreciate it.
Old November 15th, 2017, 19:40
Re: NOS Stuff
When I can find it... I sure will!
Old November 16th, 2017, 06:57
GBR928 GBR928 is offline
Not the one pictured... But another NOS. How do I infer without being insulting... Mine might be a bit pricey for your need. I'm thinking you might try: http://jwjeep.com/ for a previously-owned one if it's just to be used as a cover. Respectfully.
I checked with them and they don't have any at the moment. PM me your price for the NOS one, I'm also looking for tan leather front seat material, not sure if you may have that as well.
Old November 16th, 2017, 08:07
jpk's Avatar
jpk jpk is offline
Re: NOS Stuff
Thanks, I would greatly appreciate it. If you find it, my email is:
krol at bellsouth dot net
I am slowly restoring my 96 Country and have done many things to it over the ten years I have owned it. In addition to the cargo cover I have an OEM spare tire carrier that I want to eventually mount. I just recovered the headliner and recently took all the carpeting out, repaired any rust, pressure washed the original carpeting and installed new panels in the cargo area. I found an original Jeep, in dash CD player to replace the stock cassette player. That's just a small list. I hope to eventually find the body graphics for when I repaint it. It's not a perfect, like new resto but it looks pretty good to me.
I'd send a few photos but I don't know how to post them here.
Old November 16th, 2017, 12:10
jpk's Avatar
jpk jpk is offline
Here in Jacksonville there's a guy selling a 87 Wagoneer XJ for $1500.00. It's a 4x4 and it runs. Crappy photos show it to be in fairly decent shape. I'll try to post a link if I can find it again.
Old November 16th, 2017, 17:17
Re: NOS Stuff
I'll post the Cargo-cover instructions here in case others are interested.
Old November 16th, 2017, 17:24
For NOS materials try: https://originalauto.com/
Old November 17th, 2017, 07:41
jpk's Avatar
jpk jpk is offline
Re: NOS Stuff
Thanks for posting the instructions. However Jeep completely changed the mounts for the later XJ's. Wasn't expecting that. I'll have to look closer at the instructions to see if I can use the mount placement image that hold the cross bar behind the seat. The mounts near the lift gate are totally different in shape and mount placement. I appreciate your taking the time to do it.
Old December 14th, 2017, 18:53
Rear Bumper-guard(s) Do-over
Not all bumper-guards are created equal. And by-the-way... Neither are bumpers! Although I didn't document it... I purchased/returned many rear-bumpers before I got one to match/fit. Apparently, the rear-bumper of a Wagoneer-XJ is different than a Cherokee-XJ.
I also purchased/returned many after-market rear bumper-guards... None fit well... Gave-up and compromised.... Until now.
Note: I was only able to find NOS of the right-rear bumper-guard… As a result… The search for after-market.
I went back to where I purchased the only rear bumper that fit... Lo-and-behold… They sell left and right bumper-guards just like the parts catalog shows. Pooh on the one-size-fits-all. Below documents the journey.
Old December 17th, 2017, 11:58
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
I would have fixed the gap with duct tape, or Pucky, LOL. My next task is roof rust that is getting out of control on my Waggy
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old December 17th, 2017, 15:50
BALTANAKT BALTANAKT is offline
Re: Rear Bumper-guard(s) Do-over
Appreciate the effort your putting in. Love this thread!
Old December 18th, 2017, 13:33
Ecomike's Avatar
NAXJA# 2091
If you run across the three OEM roof guards that are mounted on the roof between the roof luggage rails, I need a set with the fittings fast.
My roof is rusting, and the bolt holes there started leaking
So I need to replace them, sand and paint the roof fast.
Old December 22nd, 2017, 16:18
Carpet Installation
ACC Essex Carpet.
At first... I couldn't distinguish between the folds, creases, crevices, or contours! It seems there is a lot of excess carpet around the edges. Not a bad thing! But a lesson-learned shared.
Will need to remove the side-panels and do some trimming.
Old December 23rd, 2017, 19:34
Couple Qs:
1-How much work is it to pull out the entire carpet set? Any idea on hours?
2-Whats the process for removing the steel sliders on the cargo carpet?
Trying to restore an xj as well. Keep up the good work.
XJ: 1987 Wagoneer Limited Or? Windshield trim? Crist Clapper Wanted: Private Party Only 5 November 13th, 2012 16:41
1987 Wagoneer XJ Limited - Trim color? Crist Clapper OEM Tech Discussion 5 July 15th, 2012 16:11
Parting out: 1987 Wagoneer Limited YELLAHEEP For Sale: Private Party Only. XJ ITEMS ONLY 8 June 25th, 2007 22:55
Parting out 1990 XJ "Wagoneer" Limited XJ&CHZ4ME For Sale: Private Party Only. XJ ITEMS ONLY 14 December 16th, 2006 22:19
1987 XJ Wagoneer 6.5" Lift on 35`s + Extras Fairmonco For Sale: Private Party Only. XJ ITEMS ONLY 12 September 15th, 2006 15:37
