Old April 14th, 2019, 12:39
trippled trippled is offline
Re: Trans-go kit into aw4 - any thoughts coments.
Originally Posted by ShoeterMcgav View Post
I get that part.. The shifter wont do anything... But this will-
http://www.radesignsproducts.com/rail-controller.html
Basically bypasses the TCM... So shift points should be cleaner is my guess? Or would you still need the vapvebody kit from transgo?
This seems easier- Ive read the horror stories of dropping the valvebody multiple times... Just wondering if the manual shifter would get the same desired effects
Trans will shift exactly the same, it just shifts when you tell it to.
Old April 14th, 2019, 15:39
RCP Phx RCP Phx is offline
In other words, if it shifted "softer" before, it still will even if you can technically shift "faster".
Old April 14th, 2019, 19:41
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
The redesigns kit will not make it shift any faster. Only the trans go kit will do that.
Old April 14th, 2019, 21:52
ShoeterMcgav's Avatar
ShoeterMcgav ShoeterMcgav is offline
I believe you guys... Just trying to figure out why then they have 2 products... If, as has been said, it is simply a shifter... Why have the rail shifter as well? If its the same thing as using the radesign shifter (which in my opinion is cool for the quick D to R and back)?
I mean... We can use the shifter to manually shift now... So i thought the rail shifter was to bypass the tcm making those shifts more instant, depending on throttle, as akin to a manual.
Cant see the importance of both designs is my hang up.. I get what the transgo kit does and at that price point find it well worth the effort to install
98xj lift 35s mid arms locked 9"/hp30 locked w warn hubs wj brakes hi steer etc work in progress..
93zj BEAST 35s Claytons LAs 44/hp30 lockers bumpers headers etc $old
Old April 14th, 2019, 22:45
Just to add to my original thoughts on the subject...
https://youtu.be/ERYxiG9Isbs
Basically says what Ive been wondering. I forgot I saw this guy installed both RADesign products and raved about how it shifts after. Good explination if you care to sit through it
Old April 14th, 2019, 23:07
The question would be what are you trying to accomplish? I sure don't understand your need to be able to shift fast between R and D?
Old April 14th, 2019, 23:20
Elliminate lazy shifts... I dig the actual shifter... D to R is an off road perk, granted one I wont benefit from as often as someone who races for a living. I can see the benefit in loose traction situations though.
The rail 2 manual shifter ellimination of the tired shift points and tcm controlling the fluid pressure etc sounds about the same as what yall want from the transgo kit. Thats all i was seeking.
The youtube video answered my questions though, thanks!
Old April 15th, 2019, 07:15
Neither the OEM TCU or the Rad units control fluid pressure. Only the TV cable and the internal metering plate does that.
Old April 15th, 2019, 08:37
Tps doesnt send signal to tcu?
Old April 15th, 2019, 08:56
cal's Avatar
cal cal is offline
It does, but that doesn't control line pressure.
Our transmissions are a lot more mechanically controlled than you appear to believe
Old April 15th, 2019, 08:57
Yes it does, but only to calculate the load in conjunction with the output speed sensor to control the "timing" of the shift points.
Old April 15th, 2019, 11:51
Apparently!
The youtube vid must have some incorrect verbage in it.. Guy is a master mechanic I believe he said at one point in another vid- so I took it at face value.
Old April 15th, 2019, 12:51
This still makes no sense ???
Old April 15th, 2019, 14:53
Ok... Going forward in deep snow... Spinning and begin to stop. Bump it to R at lower rpm back up a touch bump it to D and continue on (hopefully)
Deep puddles might see a greater use.. But incline on rocks also a benefit.
Its not an end all save all manuever, never said it was.. But it does have practical uses off road
Old April 15th, 2019, 14:54
Bump it and bang it brah!
Off the wall thoughts: or thoughts that don't require a thread. cracked-butt Non-Tech / Off Topic 46 November 5th, 2015 22:28
Installed trans cooler, now trans sounds horrible? El Taco OEM Tech Discussion 9 June 28th, 2012 16:17
Location of manual trans fill & check plug for an Aisin Trans 90 Cherokee gman OEM Tech Discussion 2 September 24th, 2004 19:20
does downshifting with an auto trans to slow or brake hurt the trans lapaul OEM Tech Discussion 12 February 21st, 2004 08:26
