Old April 9th, 2019, 14:53
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Disc swap wheel studs
I'm sorting out getting new rear axle shafts. will the longer wheel studs that you're supposed to use when doing a disc conversion work until that conversion is made, or are they too long?
Old April 9th, 2019, 16:20
RCP Phx RCP Phx is offline
Re: Disc swap wheel studs
It should but it would depend also on your wheels. What's the worst that could happen, you pick-up some std lug nuts.
Old April 9th, 2019, 17:09
I just like not to have to install shafts and find out that it's not going to work, I've got generic steelies
Old April 10th, 2019, 08:06
Just remember that whatever axles you buy to do your homework on studs. When I bought my Yukon axles, their website listed the wrong studs. My Yukon's take .618" studs so I used Dorman #610-260.
Old April 10th, 2019, 11:20
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
When I did my disk brake swap, I used wheel studs for a ford 8.8. I dont have the part number handy, but I just told the guy at Autozone I needed rear wheel studs for a 1999 ford explorer with a 5.0 engine.
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231, with a few basic bolt ons.
Click here to support
Old April 10th, 2019, 21:21
I did get Yukon, should that size be standard for xj Yukon shafts?
Old April 11th, 2019, 06:29
Yes, I called Yukon to verify that they take a .618" stud.
Old April 15th, 2019, 11:37
Did you keep the same c clips?
Old April 15th, 2019, 11:59
There was no reason to order some but I did because of future possible needs. I did use them in this thread.
https://naxja.org/forum/showthread.php?t=1149274
Old April 17th, 2019, 15:27
Found some dorman, 10 a box 12$ vs 4$ each-dayum.
Old April 18th, 2019, 08:54
Heavyopp Heavyopp is offline
I try to stay away from anything "dorman" when I can -- No I have never had anything fail catastrophically but I also don't use much of their crap either
Old April 19th, 2019, 06:25
That's fair. I kinda got to thinking if aftermarket axles are mostly made in the same place, these studs might be as well. Just seemed a waste to added money for a name attached to them. I'll see what arrives in the mail.
Show of hands, who added longer studs on ZJ disc upgrade for an 8.25? FleXJ96 Modified Tech Discussion 19 July 21st, 2012 20:17
wheel studs for disc conversion XJensen Modified Tech Discussion 3 May 19th, 2011 12:23
D-30 wheel studs? jdxj Colorado Chapter 9 July 14th, 2009 12:27
Longer wheel studs for ZJ disc on D44 swap stoneattic Modified Tech Discussion 3 July 28th, 2007 22:04
D44 Rear Disc Conversions: Longer studs needed? XpedientJ Modified Tech Discussion 6 July 12th, 2007 16:34
