Old March 25th, 2019, 13:04
notamechanic notamechanic is offline
Re: Another death wobble thread
Most will say 4-7* of caster, but because I have a LP D30 and radius arms I've been running 3* going on 20yrs now.
Thanks! Iíll take measurements tonight and see where Iím at. Hopefully itís not off since I havenít had issues prior to installing the steering.
I did just have 1 loose jam nut on the tie rod and 1 loose on the draglink. Cranked those back and will test drive to see if thatís all thatís causing it.
Old March 25th, 2019, 19:08
Tightening up the jam nuts did not solve the problem.
Here are photos of my heims
https://ibb.co/Qr9yc1K
https://ibb.co/9ybDX0Q
https://ibb.co/nLcxxK1
Old March 25th, 2019, 19:15
Gotrdone Gotrdone is offline
Did you check the bushings in your control arms? are the uppers still stock? they look like it in the pic. The uppers were the cause of a death wobble on one of my cherokee's
Old March 26th, 2019, 19:46
Sorry for the late response. Yesterday was a long one.
I have not checked but will ASAP.
My pitman arm has the slightest bit of play and makes a small clunk when I tap hard with my hand. Wonder if this might be the culprit. Just need to figure out what is causing the play.
Old March 27th, 2019, 06:33
old_man's Avatar
old_man old_man is offline
When you say pitman arm, what do you mean; where the shaft enters the steering gear or the other end with the hole and TRE?
Tom Houston - Former Colorado Chapter President , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
old_man's Avatar
Either way, any slop can cause problems.
Old March 27th, 2019, 06:35
old_man's Avatar
Old March 27th, 2019, 10:26
Seems to be where the shaft enters the steering gear. Still need to check the steering box bracket too. But the shaft definitely has a little play.
Old March 27th, 2019, 15:06
xjrick94's Avatar
xjrick94 xjrick94 is offline
I just installed the same steering and ecountered the same issue. I had no death wobble before and now I can't go over 40mph. I haven't had a chance to check for play in my front end but am hoping to crawl under there this weekend. My oem steering had a stabilizer and my current setup does not. I installed the draglink above the pitman arm.
Old March 27th, 2019, 16:49
Thatís weird. Hopefully itís not just cavfabs setup. Your drag link/trackbar angles look really good too. Iím also running the draglink over the pitman arm.
Let me know if you find anything and Iíll keep you updated on my findings!
Old March 27th, 2019, 18:19
Iím completely stumped
Checked list
Ball joints
Wheel bearings
Rod ends / heims
Alignment
Wheel balance
Everything seems okay. My bushings seem okay by just looking at them.
Put a jack under the lowers and didnít see any movement with the weight of the vehicle on them.
My uppers are stock and the bushings look okay, my jeeps just over 100,000 miles so maybe time to replace those anyways.
Old March 28th, 2019, 07:52
xjrick94's Avatar
If it wasn't for drilling out my pitman arm and knuckles i'd just reinstall the stock setup. I've never replaced the balljoints so i'm just going to start there since i should give them attention anyway. A buddy mentioned that I could have always had an issue and that my steering stabilizer may have been hiding it. So I went ahead and ordered cavfab's stabilizer mount as well. I'll have some time to look at it this weekend. I'll keep you posted.
Old March 28th, 2019, 12:40
cwyman6 cwyman6 is offline
There is a reason jeep put a stabilizer on these vehicles. Hitting bumps between 40 and 55 mph can start a oscillation that results in a death wobble. I know everyone says if everything is perfect u dont need a stabilizer but not all roads are smooth. Put a good fox stabilizer on and be done with it.
Old March 28th, 2019, 12:41
xjrick94's Avatar
The mount that i ordered shipped this morning. Hopefully it doesn't take too long to arrive.
Old March 28th, 2019, 16:05
I was thinking about ordering cav fabs mount too. Might as well. What stabilizer did you order?
Death Wobble Thread DrMoab Modified Tech Discussion 89 August 6th, 2018 11:07
ANOTHER death wobble thread....this time with all new parts! Vanquish Modified Tech Discussion 3 May 21st, 2014 18:13
Another Death Wobble thread. I'm stumped. Jeep450r Modified Tech Discussion 10 June 14th, 2012 08:53
another death wobble thread (not trackbar) whatevah Modified Tech Discussion 14 October 30th, 2011 17:58
Death Chatter.....not death wobble twoksl2 OEM Tech Discussion 18 March 10th, 2008 16:57
