Old June 12th, 2014, 23:18
CAJJ93XJ CAJJ93XJ is offline
Re: WJ power steering pump upgrade vs PSC pump upgrade
scratch that. after reading this http://www.pirate4x4.com/forum/gener...e-ps-pump.html
and this again.. for the 10th time http://www.pirate4x4.com/forum/jeep-...-steering.html
I think I'm going to try to mod the stock pump and find a bigger reservoir http://westtexasoffroad.homestead.co...rsteering.html
Old August 17th, 2015, 14:49
TORC811's Avatar
TORC811 TORC811 is offline
Originally Posted by hot_rod_hooligans View Post
I will be revisiting the WJ pump mod again on my MJ.
Did you ever try this on your MJ? Is it a HO or Renix MJ?
01 XJ - Rock Link, 4.56s & Treps
88 MJ - In rebuild hibernation
Old August 17th, 2015, 22:20
DansGreyMj's Avatar
DansGreyMj DansGreyMj is offline
Re: Re: WJ power steering pump upgrade vs PSC pump upgrade
I have a WJ pump in my Renix Mj. I followed this http://www.bsfab.net/?p=152 and it worked out perfectly.
Old August 19th, 2015, 05:47
TORC811's Avatar
Thanks!
Old January 20th, 2016, 14:16
Ben824's Avatar
Ben824 Ben824 is offline
Ok to dig up this thread again thanks to the attention given to me from another member on another thread I started in search for information on this swap, what is the general consensus on drilling out the high pressure fitting from my XJ pump?
Also, how did y'all plug the other fitting on the reservoir?
Old January 20th, 2016, 14:26
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
General consensus was to leave it alone and not drill it out, as drilling it caused it to whine.
I believe you can use, if you want, the other port to attach a power steering cooler. I've found a write up that a cooler from an F250 mates to the brace behind the bumper without much issue. Even mounting holes line up.
Dirk DeYoung--Member #176
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2006 XK (TOW RIG)
Old January 23rd, 2016, 00:32
jeeptec's Avatar
jeeptec jeeptec is offline
Definitely doing this upgrade. I found my 87 XJ was ok with 33s turning. My 00 XJ with 32s is heavy feeling.
Old May 25th, 2016, 13:25
R6TeXJ's Avatar
R6TeXJ R6TeXJ is offline
Have you done the upgrade? Any tips on how to do this? Did you have to mode the low pressure line like in the write mentioned here? http://www.bsfab.net/?p=152
I have a 97, so I shouldn't have to do the mounting stuff.
How did you plug the extra hole that the WJ pump has?
Old May 25th, 2016, 13:50
Cottontail's Avatar
Three-De Off-Road
R6TeXJ - I tried to do the WJ pump upgrade. The pump I had kept leaking out of the connection between the pump and the reservoir (reinstalled 3 times with new O-rings each time), so I just tossed my OEM one back in with a new reservoir.
When I installed the WJ pump, I didn't have to do a lot of what they said on that write up. I certainly didn't tap and thread the WJ pump bracket - there is no need, I didn't have to tweak any lines, I didn't drill out the XJ pressure line fitting. It really should be just a direct swap...with the pressure line fitting change. Next time I would try to do that change with a wrench and not a socket. I took the WJ pump and reservoir apart to move the fitting to fit the socket in and I think that I never could get it back together solid. I believe that if I had never fiddled with the reservoir separation I'd have been fine.
The extra hole, I left about 3 inches of hose on it and then stuck a big ole bolt in the end and hose clamped it down. It was suggested to me later that if I'd left about 6 or 8 inches, I could have folded up that soft line into a "U" and eliminated any possibility of fluid escaping between the bolt and the hose clamp.
I also did use a junk yard pump so that I didn't have to deal with moving the pulley from one unit to another.
Old May 25th, 2016, 14:26
R6TeXJ's Avatar
thank you!
While you had it could you notice a better feeling while turning?
Thank you for your help! I'll think I'll try and tackling this mod this weekend.
Old May 26th, 2016, 08:57
Ben824's Avatar
Ok so what I did is I used the lower return fitting and got a small piece of larger hose at the parts store because thew fitting is too big for the stock return line. I then went to the hardware store and got a reducer fitting to then drop back down to the stock size. For the smaller fitting on the on the reservoir, I originally capped it with a silicon cap from the parts store. That thing leaked like crazy even with a clamp. I finally took a small piece of hose and clamped it and then stuck a bolt in the other end big enough to fit in the hose and then clamped to that and that stopped the leaking. Aside from those two slight adaptations, the rest of the install was straight forward. I swapped my original pulley to the WJ pump because my 97 had a metal pulley while the WJ stock pulley was plastic. I also of course swapped over the fitting for the high pressure side like everyone else did. Turning seems slightly easier but not drastically. I did a lot more internet researching and found more threads discussing whether or not to drill out the high pressure line fitting. I found an interesting discussion where one guy tried drilling it out larger but not to the same size as the stock WJ fitting. What he was saying is that drilling the hole out to the same WJ size but trying to force it down the smaller XJ line with less things that all that volume of fluid has to run would cause the pump to capitate creating the noisy pump that everyone seems to complain about. He drilled it our larger and it gave him more power but it didn't create the loud pump issue. I wish I could tell you what size that was but I cannot find that web page again to tell you what he drilled it out to. I had planned to pull the fitting out and drill it out to the size he did after the dust settled moving into out new house.
Old May 26th, 2016, 09:17
Ben824's Avatar
Found it! Post #7 goes over what this guy did when he put a WJ pump on his TJ. He drilled it out to 3/16" and he says it doesn't make the horrible noise but increases power.
http://www.jeepforum.com/forum/f9/wj...-swap-1167530/
Old May 26th, 2016, 09:25
Cottontail's Avatar
Three-De Off-Road
thank you!
While you had it could you notice a better feeling turning?
It never left the garage....
Old May 26th, 2016, 12:56
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Jeepoholic
I run a WJ pump and Durango box and LOVE it. Huge difference over stock. Turns my 33's with no effort. As said don't drill out the fitting. All you need to do is swap it. You don't need to tap the pump I just got a longer bolt to go all they way through. Even that is overkill though. My biggest issue was the second line fitting. At first I had a hose with a plug with a clamp and that didn't last, crapped out driving one day gushed fluid everywhere. After that I put a new hose with a bolt and filled it with RTV or any oil resistant silicone clamped it and it's been fine. I went with Lares for my reman, they are based here in the states and cost wise and not bad, a lot cheaper than a PSC or red head rebuild. I also ran all new lines, with a aux cooler, filter and Lucas fluid. Worth every penny IMHO.
Old May 26th, 2016, 14:25
R6TeXJ's Avatar
I've read through that post a few times, just never noticed where he with a smaller drill bit. I'm thinking of trying the non-drilled version for a moment and see how that does. Then if I need to I can always drill it out to the 5/32" that he mentions.
WHATTT??!!!!
Longer bolt where? sorry not understanding.
I'm thinking of getting one from Oreilly's From work I get a discount.
http://www.oreillyauto.com/site/c/detail/MPPC/73329105/02869.oap?year=2002&make=Jeep&model=Grand%2BCherok ee&vi=1386839&ck=Search_power+steering+pump_138683 9_869&keyword=power+steering+pump
want to upgrade my power steering pump on my 99 xj mopar98rt Modified Tech Discussion 5 November 10th, 2010 12:01
Upgrade steering pump? Jump This Modified Tech Discussion 18 April 30th, 2009 10:54
Upgrade a Power Steering Pump Murphster05 Modified Tech Discussion 5 March 14th, 2009 17:11
PSC Steering Pump Upgrade Appleseed Modified Tech Discussion 1 October 13th, 2006 22:19
Upgrade power steering pump? ZachMan Modified Tech Discussion 15 February 5th, 2006 14:55
