Old April 13th, 2019, 12:32
ShoeterMcgav's Avatar
ShoeterMcgav ShoeterMcgav is offline
Re: WJ power steering pump upgrade vs PSC pump upgrade
I think a bolt with rtv is ok.. Or a line ran and cut with a bolt and rtv and a hose clamp.
Are moat of you getting these at junk yards or from the VatoZone?
98xj lift 35s mid arms locked 9"/hp30 locked w warn hubs wj brakes hi steer etc work in progress..
93zj BEAST 35s Claytons LAs 44/hp30 lockers bumpers headers etc $old
Old April 13th, 2019, 16:01
R6TeXJ's Avatar
R6TeXJ R6TeXJ is offline
Originally Posted by Car Enthusiast View Post
What did you all use to plug the secondary return line on the WJ pump?
a large bolt and a clamp. If you wanted you could even add some permetex or something similar.
Old April 13th, 2019, 20:58
Car Enthusiast Car Enthusiast is offline
I put a rubber cap and a clamp on it and it started leaking. I hope it didnt burn up the pump. I was thinking some epoxy might work, or throwing a y joint in it and just having both return ports connected.
Old April 23rd, 2019, 12:07
senTralsuLcus senTralsuLcus is offline
Originally Posted by ShoeterMcgav View Post
What was this hole used for on the dubj?? A cooler? Why just plug it? Does it not come with the cooler? I nees to find a wj friend and inspect..
It was for a cooler. Had a wj, took off pump and cooler, using cooler for transmission cooler, have pump as a reserve when my current stock pump gives out. Running bfg 32's 255/75r17 (actual 31.5) and don't feel the need to upgrade yet. Looks like it's direct bolt on a 97+ xj.
Old April 23rd, 2019, 14:01
old_man's Avatar
old_man old_man is offline
Just a word to the wise. Make sure and feed the return low pressure line to the nipple on the bottom of the tank, not the one on the side. It is tempting, but if you do, you will fight cavitation and horrible noise.
Tom Houston - Former Colorado Chapter Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old April 23rd, 2019, 17:24
don.h.jensen don.h.jensen is offline
hoping I can get a response from a thread from so long ago. Iím putting a wj pump in my xj; wondering why the xj hp fitting was put into the wj hp fitting to drill it out hooli? In your process did you use both fittings once installed into the xj? Did you use the xj hp line into the xj hp fittting INTO the wj hp fitting? Or did you make new hp lines (or have someone make) hp line with wj pump fitting and xj gear box fitting? Where Iím at is have both xj and wj pumps and reservoirs on my bench and have the xj hp fitting out on bench (wj fitting is still in the pump) I guess Iím wondering if a quick step by step could be laid out from here. Best course of action.
Old April 23rd, 2019, 17:37
Never mind. I’m an idiot. I figured it out.
Old April 24th, 2019, 13:27
When sourcing the pump is it just the 4.7 v8 wjs? I already have a cooler so im wondering if i can use the extra line instead of capping it.... Its not really making sense to me tho- where does it go from the cooler? And why does it need an extra line instead of just having the cooler in line?
want to upgrade my power steering pump on my 99 xj mopar98rt Modified Tech Discussion 5 November 10th, 2010 12:01
Upgrade steering pump? Jump This Modified Tech Discussion 18 April 30th, 2009 10:54
Upgrade a Power Steering Pump Murphster05 Modified Tech Discussion 5 March 14th, 2009 17:11
PSC Steering Pump Upgrade Appleseed Modified Tech Discussion 1 October 13th, 2006 22:19
Upgrade power steering pump? ZachMan Modified Tech Discussion 15 February 5th, 2006 14:55
