Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Non-Tech / Off Topic
Non-Tech / Off Topic The popular Non-Tech Forum. NO SPAM at all. Period.
Old September 28th, 2019, 19:00
bradleyheathhays bradleyheathhays is offline
Cooling your engine down with fans
This may sound like a stupid question, as I'm prone to ask sometimes. But...I drive a '96 Cherokee with the inline 4.0 non-interference engine and it doesn't like driving in the heat so much. Since I'm a car down right now I'm driving it a LOT more than I used to. After a lot of driving in this hot weather it starts slower, but still starts and runs ok.
So to help it out I've been raising the hood and putting 2 box fans right on top of the engine to help it cool. I hadn't thought about it but my Mom asked if cooling it down too quickly could be bad for the engine. And since I don't know I thought I'd ask here.
Any harm in using my method to cool an engine down much more quickly than normal?
Old September 29th, 2019, 20:09
Anak's Avatar
Anak Anak is offline
Stranger
Re: Cooling your engine down with fans
I don't think you will get into trouble with a pair of box fans.
Where you can really mess up a hot engine is if you add cold water to an overheated block. I believe it is possible to get enough of a temperature differential to crack cast iron in that situation. But I don't think you are going to get anywhere near that with air from a couple of fans.
Old September 30th, 2019, 17:39
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
An easier fix is the time delay relay.
https://www.youtube.com/watch?v=lUCr_QCuwE0
Old October 5th, 2019, 19:45
smccollamjr smccollamjr is offline
If the engine turns over slower when itís hot your starter might be going bad.
Rate This Thread:
NASCAR Detmar Cooling Fans - Ideal for Underhood Cooling... XpedientJ For Sale: Private Party Only. XJ ITEMS ONLY 1 March 20th, 2008 17:11
Electric Cooling Fans andyszafran Modified Tech Discussion 45 December 11th, 2007 23:22
Dual Electric Engine Fans - 11" fans - 12V - 2 speeds BigTP2 For Sale: Private Party Only. XJ ITEMS ONLY 3 December 19th, 2006 11:59
Aftermarket cooling fans Speed_racer Modified Tech Discussion 3 January 20th, 2004 11:09
aux. cooling fans wascobi OEM Tech Discussion 2 December 22nd, 2003 22:18
