OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
XJ died going down highway.
99XJ 4.0L AW4 96K
I was cruising along at about 70 and it bucked a couple times, backfired and lost all power. I put it in neutral as I was rolling to a stop and it died. I threw it in park and it fired right up and idled fine, so I continued on to where I was going. A couple hours later I was driving home and it did the same thing, I couldn't give it any gas without it stumbling and cutting out. I pulled over, let it sit(still running) for about 30 seconds and continued my drive home without any other problems. I was monitoring the TPS, Map, Timing, and Fuel flow with my Scangauge and nothing looked out of the ordinary when it was acting up. It didn't seem to have any problems until it was good and hot. On the trip home I had my fuel pressure gauge taped to the windshield and fuel pressure stayed at 50 +/-2 PSI. What the hell is wrong with this thing now? A little history on it... A few weeks ago I had a bucking/surging problem under throttle that was fixed with an IAC.(the details of that can be found here http://www.naxja.org/forum/showthread.php?t=926165 ) A week ago I had some hesitation when it was first switching into closed loop mode that would sometimes throw a code P0135. That was fixed with an upstream 02 sensor(along with a header, a new cat, and a catback) It had been running fine all week during the same drive in basically the same conditions and I would like to think this is a new problem. Work that's been done/parts that have been replaced. Exhaust manifold replaced with header New Cat New up and downstream O2 Sensors New IAC New Cap/rotor/plugs/coil New muffler and tailpipe New Crank Position Sensor Grounds Cleaned/replaced Fuel injectors heat wrapped Vacuum hoses checked, double checked and a few replaced. I haven't done any troubleshooting yet on this problem with the exception of watching the scangauge and hooking up the fuel pressure gauge on my drive home. I bought this thing hoping it would be a good Daily Driver and so far it's really been letting me down. |
#2
Re: XJ died going down highway.
Sounds like Crank Sensor....but you said that is new...so....ya got me. How long ago was it replaced? And did you get one from the dealer or....?
EDIT: Did it throw any engine codes???? |
#3
You described the classic signs of either a bad crank sensor or cam sensor. Also check the harness and connections.
#4
Picked up the Cam sensor they ordered for me and took it out to the parking lot to install... wrong sensor, it was a little smaller and wouldn't fit in the distributor right and the bolt holes didn't line up. Took the old one into the store and crossed the Chrysler number on it and it came up with the one that they sold me... The box was a little beat up so they are thinking it might have got switched with another one at some point, and have another one coming in for me tonight...
If it wasn't for bad luck I wouldn't have any luck at all. |
#6
Yeah the cam sensor has to be matched to the distributor number; there were two different types for the HO engines. Murphy's Law states you'll always get the wrong one.....
At least they're very easy to change, and a new one should fix your problem. Mine acted the same way when the cam sensor went out on my 96. |
#7
They are easy to change, it's about a 3 minute swap. I wish all the sensors were that easy to change. |
#8
Got the right Cam Sensor and got it installed.
I drove my normal test loop that I was always able to duplicate the problem on twice and I never had a hiccup. looks like another problem fixed. I wonder what will break next. |
#9
did you replace the crank sensor for this same symptom/issue?
If not, i would bet you'll be back here with the same problem.. |
#10
I'm fairly positive that this issue is fixed. I was able to duplicate the problem several times and after the cam sensor was replaced I did the same drive under the same conditions and I wasn't able to duplicate it. |
#11
One thing you might want to try: if your fuel pressure guage has a bleed hose, do a volume test on your fuel pump. I had some similar problems(dying on highway when hot, bucking ect.) The guage said i had 50 psi, but it was 50 psi of vapor
Thread Tools | |
Display Modes | |
Died on highway...wont restart | OverlandZJ | OEM Tech Discussion | 10 | April 20th, 2007 10:12 |
Starter Solenoid died...replaced....died... | RickyN29 | OEM Tech Discussion | 9 | January 3rd, 2007 18:02 |
died ABS on a 91 xj - please help | Micha | OEM Tech Discussion | 12 | December 31st, 2006 04:43 |
91 XJ Died | phxjeep | OEM Tech Discussion | 11 | September 6th, 2006 08:47 |
Help it died. | foodog2 | OEM Tech Discussion | 3 | August 27th, 2006 19:05 |
