Old July 12th, 2007, 03:34
newjeepowner newjeepowner is offline
Looking for someone to install a 3 inch lift. in Lower Michigan
I am planning to put a 3 inch lift with springs and shocks all away around. Maybe a Sky lift. Anyway. I got a price from a local 4X4 store. Seemed kind of expensive for the labor. I thought about doing it myself but am afraid to run into problems and not have the proper tools. I live in southeast Michigan. Who else works 4X4 jeeps in my area????? I have a stock 99 Xj right now that I plan on doing the suspension upgrade on.
Old July 12th, 2007, 04:05
jvancamp jvancamp is offline
Re: Looking for someone to install a 3 inch lift. in Lower Michigan
When do you plan on doing it?
Old July 12th, 2007, 04:29
Within the next 1 to 2 weeks. If I don't find someone or somewhere else to do it I will stick with my original quote. ROCK ME HARD PLACE
Old July 12th, 2007, 04:39
scoobyxj's Avatar
scoobyxj scoobyxj is offline
PM monkeyevel (owner of JCR Offroad) I bet he, or one of his minions could help you out. They're in Kalamazoo.
Old July 12th, 2007, 04:53
I'm in Flint. Floor lift and tools.
I lifted a YJ last year 3.5" plan on lifting my XJ 3" so I'll be doing one sooner or later.
Just PM me when you get close to doing it. Will work for food
Jeff
Old July 12th, 2007, 05:43
Have to figure out what kit I will buy. Will I need new brake lines and transfer case shim for a 3 " lift?
Old July 12th, 2007, 05:48
Make sure the kit includes shocks or you have the correct length shocks on the day you lift it.
I used Black Diamond on my YJ and was happy with it. I'm sure there are many others on here that could point you in the right direction for a kit.
Old July 12th, 2007, 06:08
Looking at the Skyjacker kit with shocks, springs and full leaf. Not sure if that one or the add a leaf kit. What about brake lines?
Old July 12th, 2007, 07:32
scottmcneal scottmcneal is offline
don't do add a leaf. full leaf pack, it cost more but will last an ride better..For a three you don't need lines just move yours.
Old July 12th, 2007, 09:54
JEFF's Avatar
JEFF JEFF is offline
You will need a longer rear brake line that mounts from the frame to the axle tube, the front lines can be bent stright and relocated. When you buy a suspention system make sure it comes with everything you will need. I have a RE 3.5 superflex, and it came with everything I needed except a t-case lowering kit.
Old July 12th, 2007, 19:56
fishfighter fishfighter is offline
Start no spraying everything with something that will break down rust.I did that two weeks before installing my 3" kit.What I had found was alot of people break off the bolts that hold the shocks.By spraying them down,I didn't have any problems.I had used SeaFoam in a spray can.I installed the Rough Country 3" kit with AAL's.Check how high the xj sits now.Check the center of the rim to the bottom of the finder flair.The front should be 17",the back 17.5".If that is what you have,your back springs are good and you can get away with a AAL.
Old July 12th, 2007, 22:22
4x4life05's Avatar
4x4life05 4x4life05 is offline
That's what I thought too, but my leafs started to sag really bad within a month or two with practically no off roading! I'd say go rough country with the full packs, I have the 3" and full leafs, I ended up getting about 4.5" with the kit. And for the price, you can't beat it, not to mention the awesome customer service. Didn't need to mess with the brake lines either, still get awesome flex too!
Old July 13th, 2007, 00:00
poopy01 poopy01 is offline
Where in se MI. Im in southgate.
Old July 13th, 2007, 00:01
HaleYes's Avatar
HaleYes HaleYes is offline
Actually, Daryl is co-owner. Brian is the other.
Brian is actually the head-cheese, and just lets Daryl think he's important but he's really not.
I'm sure they'd be happy to do an install for you. Give them a hollar.
Hale
Old July 13th, 2007, 01:36
I'm in Roseville located in Macomb County
How my mild 3 inch lift grew into a monster 6.5 inch lift AlabamaBill South East Chapter 6 June 5th, 2007 01:07
Is it normal that the drivers side of my XJ is .75-1 inch lower than the passenger? Plays For Jeeps Modified Tech Discussion 26 April 25th, 2007 15:54
3.5 inch lift with 12.5 inch wide tires 97babyXJ Modified Tech Discussion 11 December 27th, 2006 20:11
1st timer 3 inch lift install a1collier Modified Tech Discussion 1 October 16th, 2006 10:44
lift setup? 3 inch and 2 inch bb vajeeper Modified Tech Discussion 2 December 21st, 2005 22:41
