Old December 7th, 2006, 19:12
WreckerL WreckerL is offline
Angry Rear Wheel Bearing renewel 96 XJ
Hi there all Im new to this Forum and have problem with removing the rear wheel bearings on my XJ. I tried removing the passenger side a couple of weeks ago to no avail. Looking at the Haynes Manual and also OEM manual.
Do i need to remove Diff cover and remove the circlip on the inner bearing to be able to pull out the half shaft.
regards WreckerL
Old December 7th, 2006, 19:13
CanMan's Avatar
CanMan CanMan is offline
Re: Rear Wheel Bearing renewel 96 XJ
regards WreckerL
What rear axle are we dealing with? D35? D44? 8.25? What year rig too?
Old December 7th, 2006, 19:16
The Rig is a 96XJ with a D35 Axle
Old December 7th, 2006, 19:18
CanMan's Avatar
Yea, to remove the axle shaft, remove the tires and drums, remove the diff cover, remove the bolt or spring pin holding in the cross shaft, push axle inwards, and the C Clip will fall out, pull alxe out, and you will have access to the wheel berrings.
Old December 7th, 2006, 19:22
Thanks alot for your help CanMan
The Manuals were not to specific about going into the the Diff but the drawing I had did show a circlip on the end of the shaft
Old December 8th, 2006, 18:06
mikeny59 mikeny59 is offline
NAXJA Member #300
just did my 8.25, interesting minor obstacles,
pm me or just reply and i'll go through some tricks and tips i otherwise would never have dreamed of.
Old December 8th, 2006, 18:32
PhotographerMike's Avatar
PhotographerMike PhotographerMike is offline
The "C" clip is held in a groove in the gear carrier and slips / falls out when the axle is pushed in slightly.
I recently changed the seals in my 8.25 and since I had some time to kill waiting for parts I just happened to have snow chains on checking for fit. Holding the wheel by the chains sure made it easier to re-install the axle without hurting the seals. ALSO; with the 8.25 (I haven't done a Dana) the seals were a VERY tight fit. I needed to to freeze the seals, heat the seat with a heat gun and work fast with a rubber mallet to get them in.
Mike
Old December 8th, 2006, 19:16
NAXJA Member #300
http://www.naxja.org/forum/showthread.php?t=103627
any questions?!?
lubricate rear wheel bearing? torfinn OEM Tech Discussion 1 April 17th, 2006 23:01
Wheel Bearing help please LilRedRover Modified Tech Discussion 1 March 2nd, 2006 12:34
hub/wheel bearing JVRacer04 OEM Tech Discussion 7 September 11th, 2005 08:14
Wheel bearing replacement? Rear? Not sure?! summitlt OEM Tech Discussion 0 August 24th, 2005 05:28
Rear Wheel Axle Bearing and Seal Replacement Thayer OEM Tech Discussion 4 August 2nd, 2005 19:12
