Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
Axle wrap on front axle ???
I don't know how major this could be, but here it goes
As I was backing out today, I noticed a clunk when I would hit the brakes. It felt weird, but the brakes were working fine, so I didn't worry about that. When I had a friend back it up and look, I saw that my axle was actually twisting clockwise, as in the pinion would jerk downwards. Now, I don't know exactly how an axle with coils and 4 control arms could do this, but I want to know if anyone's heard of it. I tried searching, but oddly enough, it doesn't seem to have happened to anyone on here. |
#2
Re: Axle wrap on front axle ???
worn bushings, loose bolts, etc
#3
Talkin about worn bushing on the control arms?
#4
Well that's just super
#7
That is typically worn out upper control arm axle bushings. With a home made bushing tool or a ball joint press they are pretty simple to replace. I can do one in about 15 minutes.
TEAM ![]() Check out the TEAM ![]() ![]() Thanks to ![]() |
#8
How can I get those bushings out with basic tools? I'm going to try and replace those upper arms anyways, they are too short
#9
i got some poly UCA axle bushings for like 30bux, still havent put em in cuz i dont know how to do it
btt... |
#10
CRASH |
#11
Rent/borrow a c-frame ball-joint press from your local parts store, or buy one from Harbor Freight for $40 - should take them out in no time.
Good for u-joints too. http://www.harborfreight.com/cpi/cta...emnumber=38335 |
#12
the new adjustable UCA's will use the same bushings FYI... though it is a good idea to replace the bushing while parts are already out...
here's my RE UCA install - i kept the old bushings... http://www.opiebennett.com/upperdrrveshaft.htm another option is currie makes johny joints to go in the UCA axle end bushing holes...
Nothing in Moderation ![]() |
#13
I got tired of replacing worn bushings so I stopped running them.
Thread Tools | |
Display Modes | |
Front axle question | bustednutz | OEM Tech Discussion | 4 | November 1st, 2004 19:10 |
need a little front axle advice... | kewlkatdady | Modified Tech Discussion | 23 | October 21st, 2004 13:00 |
Front axle U-joints, Need replacing | BskisXJ | OEM Tech Discussion | 9 | September 15th, 2004 12:55 |
How far forward can I push the axle before interfering with the front inner fender?? | Safari Ary | Modified Tech Discussion | 8 | December 11th, 2003 10:21 |
Need to know quickly, Axle ??? | Big Hank | Modified Tech Discussion | 4 | December 7th, 2003 22:02 |
