Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
Rubicon TJ D44 Front Axle XJ Swap
Since TJ owners convert to a high pinon d30 from a XJ and its a direct bolt on, would a D44 front axle housing from a Rubicon TJ be of an advantage to swap on the front of an XJ? Since you can now find many Rubicon Axle housings on ebay i thought this might be a good time to upgrade to match my D44 Rear?
#2
Re: Rubicon TJ D44 Front Axle XJ Swap
If it's free yes. If its $1500 like most absolutely not. There have been many many discussions about the Rubicon front d44s...search
#3
I agree w/Basalt.
But I personally would give the Rubi 44 more credit than most guys do...Especially when you only plan on running 33s w/said rig. (Like me) A rubi 44 would be primo in my situation, and I'd buy one if it were 5-600. But not what I've been seeing them go for. (1500+)
2000 XJ 5.5" Lift w/Deavers and TNT arms, 30 front w/Super 30 kit, ARB, truss, etc. 44 rear w/35 spline alloys, ARB, Wilwood discs, truss, etc. Hooligan stiffeners front to rear, Hooligan fenders, Trailready front bumper, JCR rear bumper w/tire carrier. *under construction* |
#4
Same shafts as a LP/HP D30. Same knuckles, brakes, ball joints as a LP/HP D30. HP D30 R&P is about the same strength as a LP Rubi D44. HP D30 has better prop shaft angles. What's the advantage? Hell of a lot of work just for larger carrier bearings. r@m |
#5
Its a bolt in....it comes with a selectable locker and the 4.10s I want....
#6
not hi-jack but.....
30 spine inners / 27 spine outers, which u joints would they share? 297/760's? -g |
#9
Can you get the Rubi axle for cheaper than an ARB and R&P install? Not likely. Every complete Rubi axle ready for install I've seen for sale is over $1400 or so - most much more. I still think the shaft angle that comes with a HP D30 is more important than any "advantage" a Rubi D44 has - especially if you have a NV242 t-case (my bias). $0.02 r@m |
#10
I bet if you bought a selectable locker/gears/and alloy shafts you would have spent the same amount of money as a rubi 44, but have a HP30 that is stronger and geared deep enough to wheel big tires..
#11
That was my point, so Id probably never end up with a Rubi 44, but if there WAS one for 600$, id run it. ![]() ![]()
#12
Good score! r@m |
#13
I'ld buy it for $600, sell it for $1200. Tell the guy he's getting a great deal, and put the money into the hp d30
#14
Thread Tools | |
Display Modes | |
Swap 4.0 for 4.0HO | DADDJP | Modified Tech Discussion | 2 | August 18th, 2005 18:46 |
I dumped the 86 CV axle shafts for newer 297 TJ axle shafts. | DaveB | Modified Tech Discussion | 1 | January 3rd, 2004 06:08 |
Tj D44 | Gecko | Modified Tech Discussion | 2 | December 27th, 2003 16:15 |
MJ Axle To XJ Swap Questions | Jared | Modified Tech Discussion | 4 | September 8th, 2003 16:52 |
front axle switch/regear/xcase swap? | RNMedic | Modified Tech Discussion | 2 | April 24th, 2003 14:25 |
