OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
#16
Re: Code P1698 P1694 P0700 + Airbag light and Gauges on/off
You need to inspect the tailgate wire harness at and near the hinges and rubber boots. Failure of the drivers door wire harness and tailgate wire harness is very common. Since the power door locks are always "hot", a short circuit to another wire circuit, to the speaker wires, or simply to ground, can introduce 12 volts to other circuits, including the CCDBus. Disconnect the driver door wire harness and the tailgate wire harness from the main body wire harness to isolate any potential short circuits and continue your diagnostics. . ![]() . . ![]()
. ![]() . Quote:
#17
I finally got some time to inspect the rear hatch harness. I found two wires with broken insulation. They didn't seem to be touching anything but I taped them with electrical tape. Sure enough this morning I had the same thing happen. Wipers running and rear defroster and fog lights on when I turn on the parking lights. What would disconnecting the rke module do? |
Thread Tools | |
Display Modes | |
98 XJ Limited codes P0700 & P1694 | Dmondeac | OEM Tech Discussion | 1 | February 22nd, 2015 11:53 |
Check engine light on P1694 code | dannyg81 | OEM Tech Discussion | 8 | June 22nd, 2012 14:22 |
All Gauges keep going dead, then airbag light comes on | Wheel_Works | OEM Tech Discussion | 34 | March 23rd, 2011 10:08 |
Code P1698.....Please Help! | ColoradoRaptor | OEM Tech Discussion | 6 | September 28th, 2008 10:31 |
Code P1698 any help? | Roxtar | OEM Tech Discussion | 5 | September 12th, 2004 20:13 |
