OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
2 no bus codes p0700- no start
Hey so here's my story. I had to replace my ecu earlier in the week due to no charge function and no communication with my pocket scanner as well as with a Matco scanner. I replaced the ecu and gained all dash function back as well as communication with my ecu. My issue now is no bus no communication. I can still read the 3 codes with my scanner but not erase them. I do have injector pulse. The guages work perfect. The no bus is not lighted on the dash. I don't even see the light for it even it was to trigger. The 3 communication codes does not trigger the light. The light only triggers when I pull a sensor. If I were to leave the airbag to the steering wheel disconnected would this trigger this code? The new ecu is a salvage ecu from the same year Heep. Vehicle is a 97 country. Thanks.
Thread Tools | |
Display Modes | |
2 no bus codes p0700- no start | steveob17 | OEM Tech Discussion | 9 | July 6th, 2014 15:00 |
Codes 743, 753 Where to start? | Ice RHD | OEM Tech Discussion | 37 | March 16th, 2011 13:56 |
Codes P0700 and P0743 - Cant pass emissions and get tags until cleared. | epitaphmike | OEM Tech Discussion | 4 | June 17th, 2010 15:36 |
HELP! NO START obd codes: 11, 12, 43 | redXJay | Modified Tech Discussion | 10 | March 8th, 2006 14:07 |
P0700 & P0705 error codes | DaveB | OEM Tech Discussion | 0 | February 24th, 2005 08:21 |
