Old February 3rd, 2023, 06:46
bradleyheathhays's Avatar
bradleyheathhays bradleyheathhays is offline
Simple remote starter for the old XJ
I'd like to install remote start on my '96 XJ so I thought I'd write the boards first to get some opinions.
First, quality is important but being inexpensive follows close behind, so a simple start system will do. I'm not looking to hook up anything else like door locks or rear hatch or whatever.
Because of the truck's age the remote start might need a tach wire but I'm not entirely sure.
Any suggestions for a decent remote starter that'll work with my XJ?
Thanks.
Old February 5th, 2023, 14:39
Re: Simple remote starter for the old XJ
Anyone?
Surely I'm not the only person interested in this.
Old February 5th, 2023, 14:48
RCP Phx RCP Phx is offline
Your kit should provide you with most what you need if your just looking for specific terminals then your year is required.
Old February 5th, 2023, 15:39
Bottom line is you will need a kit that is compatible with a '96 Jeep. The cheaper universal kits are going to give the most headaches installing.
Old February 5th, 2023, 22:30
Gotcha. Thanks RCP.
Old February 6th, 2023, 09:36
Unclewolverine Unclewolverine is offline
Last time I installed a kit, 10+ years ago, even cheapo sellers would supply you with wire color instructions if you gave them the vehicle.
Remote Starter DaveD912 Non-Tech / Off Topic 4 November 26th, 2007 10:37
issues with remote starter saweddoffjeep OEM Tech Discussion 4 January 8th, 2007 14:06
Best Remote Starter? OEM? mtsz52784 Modified Tech Discussion 6 November 1st, 2006 05:21
remote starter... mikeny59 Modified Tech Discussion 7 November 13th, 2004 02:30
Remote starter Andy in Co. OEM Tech Discussion 4 February 1st, 2004 16:59
