Old September 2nd, 2008, 05:26
philip_g philip_g is offline
rear wheel bearing vs axle bearing
are they one in the same? I'm confused, the parts database lists both but they're different part numbers, what's the difference? (8.25)
Old September 2nd, 2008, 12:38
mjma's Avatar
mjma mjma is offline
Re: rear wheel bearing vs axle bearing
axle bearings are probably the carrier bearings.
Old September 2nd, 2008, 16:23
gotcha gotcha, thanks
Old September 2nd, 2008, 18:24
Jess Jess is offline
axle bearings go around the shaft near the brakes
carrier bearings go inside the diff near the splines
Old September 2nd, 2008, 19:04
except they're not called carrier bearins and axle bearings in the parts DB I'm looking at, hence the question.
Wheel bearing or axle? Tommy4949 Modified Tech Discussion 18 February 29th, 2008 20:05
rear wheel-bearing seal BADaXJ Modified Tech Discussion 9 January 3rd, 2008 11:57
Rear Wheel Bearing renewel 96 XJ WreckerL OEM Tech Discussion 7 December 8th, 2006 19:16
Rear Wheel Axle Bearing and Seal Replacement Thayer OEM Tech Discussion 4 August 2nd, 2005 19:12
Axle Bearing and Carrier Bearing Puller XJWheelie Modified Tech Discussion 1 December 9th, 2004 16:14
