Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Adventure Forum
Adventure Forum A place for outdoor side of your XJ/MJ. Discussions revolve around camping, equipment, and camping trailers. As well as outdoor activities that take off from your XJ/MJ like hiking, geocoaching, and rock climbing. Also the place to discuss tips and hints for the best places to camp off the beaten path.
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old May 27th, 2010, 10:57
old_man's Avatar
old_man old_man is offline
Starting offroad teardrop build
I am starting my offroad teardrop build over the Memorial Day holiday weekend. I got all the steel together for the frame and suspension, I got my axle, and the stuff to make my hitch. The tires are 31's.
I am building the suspension using a single RE Superjoint and a panhard bar system. I have the airbags for the suspension and adjustable shocks. The outside of the frame is 2x2 thin wall with cross supports being 1x2 thin wall. The tongue is 2x2 11 gauge. I am fabbing up a Treg hitch knockoff. I am making the mold for the neoprene vibration dampener and will pour them myself. I have been pouring neoprene parts for 20 years so this is no big deal.
I have been tossing around the idea of making a half dozen hitches while I was at it since I have the material. Anybody interested?
Once I get the frame made I will add the metal scaffolding for the top. Unlike most folks I like the frame to be steel rather than wood. I can probably do it stronger and lighter that way. I am modifying a set of dies for the roller to handle the 1x1 box for the upper body. That way I can get nice smooth arcs.
The outside will be skinned with Filon and backed with luan. Filon is what all the motorhomes use for skin. It handles hail and abuse without dents. It will be insulated with 1" styrofoam sheets. The interior will most likely be covered with foamed ABS panels. They are lightweight and strong, as well as cheap.
The galley will have a stove top and a pull out BBQ grill as well as a sink and 12v blender for my margs.
I already snared a 12v propane forced air furnace that uses a thermostat.
There is a front expanded metal shelf that will hold a 20lb propane tank and 4 NATO style jerry cans.
I hope to start posting pix this weekend.
Old May 27th, 2010, 11:42
DrMoab's Avatar
DrMoab DrMoab is offline
Re: Starting offroad teardrop build
Have you priced the Filon yet? I've heard it is prohibitively expensive.
Old May 27th, 2010, 12:23
xj-grin xj-grin is offline
NAXJA Member #1096
Can't wait to see it, Tom. Let me know if you need a hand with anything and I'll time it for my trip up to pick up my axle (with the achilles and all...).
Old May 27th, 2010, 13:01
XJBANKER's Avatar
XJBANKER XJBANKER is offline
0IIIIII0
You should check out this tear drop style trailer
http://www.expeditionportal.com/foru...ad.php?t=18142
Also do you have info on what the hitch will look and act like? Intersted depending on price.
Old May 27th, 2010, 13:13
old_man's Avatar
I like the looks but the shape isn't as practical as a simple teardrop.
The biggest design issue is dealing with the fact that if you lift the trailer the galley gets too high. I am looking at having the lower back swing down and provide a surface to stand on.
Old May 27th, 2010, 14:01
old_man's Avatar
The hitch will look something like this.
I am upgrading the materials a bit. I am also going oillite lubed bushings on the swivel instead of steel on steel.
Old May 27th, 2010, 13:10
old_man's Avatar
I found a place where I can buy the filon wholesale. It isn't cheap but about the same as the alternatives.
Old May 27th, 2010, 21:05
fireLt. fireLt. is offline
Nice Tom. Glad to see you finally get to start this project!
Old May 28th, 2010, 08:34
blacksheep01 blacksheep01 is offline
Does the left side connect to the vehicle? Does it connect through the receiver?
Old May 28th, 2010, 11:10
Char-Broil's Avatar
Char-Broil Char-Broil is offline
I would be interested in a hitch like this. would it plug into a standard 2" receiver? let me know what the cost would be if you want to make up more than one.
Old May 28th, 2010, 19:36
SWAMPMAN SWAMPMAN is offline
although those hitches are really cool and supossed to be quiet.. think about it and resarch them .. i am not convinced they are so great.. too many threads on the other forums where these type of hitches break and bend outta shape.. yes a pintle hitch is noisey .. but they are solid !
Old May 28th, 2010, 19:45
old_man's Avatar
There are two ways to mount the hitch. It can be mounted by a bolt through a standard hitch or a 2" receiver insert can be used.
I am making this from significantly thicker and stronger material. I am also increasing the size of the poly isolator to allow for a larger swing in the hitch. I am using all grade 8 bolts. They use a lynch pin, since I don't have easy access to that, I am substituting grade 8 bolts with locking nuts.
Just for everybody's information, I am an engineer and design stuff like this on a regular basis.
They sell for $150, so I figure all finished and powder coated would be $70.
Old May 29th, 2010, 11:39
GSequoia's Avatar
GSequoia GSequoia is offline
Everyone says I'm a jerk.
Are you done yet?
Prior President & Prior SoCal Chapter President
Originally Posted by Bent
Us normal people...
Old May 31st, 2010, 20:15
DrMoab's Avatar
I just pulled my trailer over 350 miles of dirt roads. Including some fairly heavy 4wd roads and I was actually surprised by the pintle hitch. It isn't as noisy as I thought it would be.
Old June 8th, 2010, 08:55
OverlandZJ's Avatar
OverlandZJ OverlandZJ is offline
NAXJA Member # 101
Tom, any pics of your progress yet?
Rate This Thread:
Building an offroad teardrop flingshot Tow Rigs and Trailers 31 April 24th, 2011 13:35
Looking for an offroad trailer to build- Jared Intermountain Chapter 30 July 6th, 2008 14:57
Need Help Om Starting A Build....... Trezurratt Modified Tech Discussion 5 September 29th, 2006 17:01
Starting my build icu_runnin Modified Tech Discussion 6 June 22nd, 2006 13:39
!!!Offroad Teardrop camper!!! MikeD For Sale: Private Party Only. XJ ITEMS ONLY 0 September 4th, 2003 09:16
