OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Factory Leaf Spring Bolt Size
I am having some confusion on what size the front leaf to frame bolt is. I am finding part numbers referencing M14-2.0x120mm but various parts suppliers are listing 9/16" or 5/8" bolts. I know these are all similar size bolts but length and thread pitch are very important. I want to make sure I replace all the hardware when I refresh the suspension. The new rear shackles came with bolts so I am good there. Thinking a grazable bolt would be nice if possible.
#2
Re: Factory Leaf Spring Bolt Size
The factory hangers are 14mm, everything else doesn't really matter. I run American threads where possible.
#3
So the captured nut on the leaf to frame and upper shackle to frame are the 14mm, but any through bolt with a nut you run standard is what you are saying?
#4
You could do that, yes. Bear in mind 9/16 is 0.29mm larger than 14 so you may have to run a 9/16 drill through the bushing sleeves to clean them out and/or remove a little metal before the bolt will fit through if they were pretty tight on tolerances.
The weld nuts in the frame for the leaf eye and shackle are M14x2.0 and more trouble than they're worth to replace, but you can do whatever you want at the shackle to leafspring connection and front lower control arm mounts, which use the same bolts.
My yard looks like Sanford & Sons. Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread. Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want. CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable. |
#5
9/16 bolt fit on the factory shackles and leaf springs
Sent from my iPhone using Tapatalk |
Thread Tools | |
Display Modes | |
leaf spring bolt size PLEASE | xjnewbi | OEM Tech Discussion | 29 | May 1st, 2017 16:53 |
Leaf spring bolt size not 120mm? | mdmbkr | Modified Tech Discussion | 15 | November 18th, 2012 17:43 |
Leaf spring bolt size | cjsxj87 | OEM Tech Discussion | 3 | December 29th, 2009 11:56 |
leaf spring bolt and spring clamp replacement? | cjben | Modified Tech Discussion | 6 | December 27th, 2006 14:06 |
Leaf Spring Bolt Size? | xj92 | Modified Tech Discussion | 4 | July 15th, 2004 10:11 |
