Relay Dual Light Wiring Harnesses (Relay, Fuse, Switch, and Connectors) - $10 each
freerider15
FoCo, Crawlorado
So I will shorty be becoming a vendor on here.
An order I received came with harnesses that had a different connector than I specified. So instead of retrofitting them all, I'm looking to try and offload them. I currently have 75 of these harnesses.
The harnesses have:
- 40A Relay
- 30A Blade Fuse and Holder
- Switch
- Dual Sets of Insulated Spade Connectors to connect two lights
Pictures of the harnesses:
These would be great for adding a pair of lights (which I will be a vendor for soon), or other accessories you'd like to be able to add with a switch.
If you're interested in more than one pair let me know, as I can give a discount on multiple harness.
I can fit several of these in a flat rate box :D
