FRONT DANA 30 noise
Mountaincajun
FRONT DANA 35 noise
4 wheel drive works great. running synthetic gear oil. going straight i have no problems when im in 4 wheel drive and i have the wheels turned al the way left or right i hear a metallic squealing noise. the noise is slow and is the same speed that i am moving..HELP..is this the brake dust shield? or do you guys think it is the spicer u-joints?(stock i believe 170,00 miles..33" MTZs if that helps..:gonnablow
Something is probably rubbing, can you grease your joints to be sure? Have someone stand next to your rig as you move slowly and try to pinpoint the noise.
-Alex
