92+ ABS sensor and braking power dist.
Greg_pl
Poland
I lost my ABS and scanned a code, that rear right speed sensor is gone. It's a Chrysler (Teves?) ABS (not Bendix) on a Dana 35. Now the question: will a sensor from a '95 Grand Cherokee (also rear Dana 35 with drum brakes) fit, are those the same?
The second one: on cars without ABS there's a device, where you can set up brakeing force between front and rear wheels (prop..something valve). But is it also on ABS equipeed vehicles or is ABS the only thing that distributes stopping power between axles? I'm asking because I lost ABS few days ago and now my rear brakes locks too soon causing nervous behavior when braking - will it go away after new sensor or are those two separate problems?
