chrisser
- Spencer WV
So I'm replacing door hinge pins in the front doors of my Cherokee.
Already had the doors off to fix the rusty rockers so it seemed like the best time.
Using the kit that comes with the new bushings, pin, sleeve and the retaining clip
Other than being a PITA to get the old pins out, the first (top driver) one went fine.
Second one (bottom driver) went OK, but when reassembled it's still a bit loose. Not as bad as it was, but not as tight as the first one.
The old bushings came out partially intact - there was still complete coverage around the pin. I went through the other kits and all the bushings are sloppy around the pins, so I assume the bushings tighten up when pushed in the holes.
Anyone else have this problem? Is there a solution other than welding up the old holes and redrilling or getting new hinges and welding them on?
