Old November 12th, 2008, 12:05
BADaXJ BADaXJ is offline
Idle Issues
'91 4.0L: when i start it up and it's cold outside, it idles up to about 2k RPM until it warms up then it idles normally for the most part. but if it idles for any extended amount of time, it will once and a while sound like it wants to die. it's just a real quick sputter, like a mis-fire/ back-fire almost. it's fine for the most part but once in a while it's just a real quick sputter, like when the aux fan or a/c kicks on in a car... sounds like the high idle could be a vacuum leak but would that make sense if it goes away when it warms up? what about the IAC? do you think the fuel pump could be the surging/cutting issue?
thanks
Old November 12th, 2008, 12:46
89xj 89xj is offline
Re: Idle Issues
should be in oem tech, but
could be dirty/sticking iac
could be loose intake/exhaust manifold bolts. once the manifolds heat up it could seal the leak.
if you suspect a fuel pump issue, put a gauge on the fuel line and test it.
Old November 12th, 2008, 13:58
Re: Idle Issues
yeah, you're right... i posted in the wrong forum. my bad, i haven't been on for a while and wasn't thinking... i'm going to try cleaning everything and checking the usuals as i haven't really looked into it yet, just looking for ideas right now since i havent had time to tear into it. thanks
Old November 12th, 2008, 15:47
ehall's Avatar
ehall ehall is offline
Re: Idle Issues
the IAC is cheap enough that it should be replaced whenever anything weird happens with the idle... that's what the idle air controller does
my '91 beater rebuild
AW4/Idle Issues IHWheelin OEM Tech Discussion 3 February 1st, 2007 22:50
Where else to look for idle issues. dyna OEM Tech Discussion 7 June 13th, 2006 21:07
Idle issues and I have searched... TK99XJ OEM Tech Discussion 8 March 8th, 2006 16:44
90 xj idle issues low_life OEM Tech Discussion 4 May 12th, 2005 22:09
Idle Issues cmeuzelaar OEM Tech Discussion 3 January 17th, 2005 19:22
