docboy209
- Selkirk, NY
I just had an idea pop into my head about true dual exhaust. Anybody do this yet? Haven't found any posts.
I have a '98 4.0 with the stock manifold. I was thinking about using the seperate manifolds from an '01, the close coupled cats, and then just running 2 pipes welded together for clearance reasons out the back. Since it's my daily driver I figured on using the bank 1 upstream O2 sensor, and the bank 2 downstream O2 sensor to fool the PCM therefore not tripping the check engine light for rich/lean/convertor efficiency codes. Then where the muffler is now just spread the pipes and stagger some slim glass packs just to calm the noise a bit.
Any thoughts???
___________________________________________________________
"When it comes to being the soothing light at the end of your tunnel, it's just a freight train coming your way." - James Hetfield
Any thoughts???
