- Near Rochester NY
My 1990 Cherokee 4.0L takes a long time to start. I need to crank it about 30 seconds before it fires. It is just as hard to start next time, hot or cold.
I noticed that the fuel rail pressure bleeds down to nothing after about 2 minutes. From reading all the cautions in the FSM, this rail is supposed to hold the pressure, right? I clamped off the return line from the regulator and still have the problem.
Surely there is a check valve somewhere in the system to hold this pressure. Can anyone tell me where it is? I am open to any other suggestions you may have.
TIA!
TIA!
