Old August 16th, 2011, 08:23
91to99 91to99 is offline
Re: Stock steering damper removal, the easy way!
Originally Posted by MileHiXJ View Post
I used one of these things. It's from Harbor Freight. Also used it to get the steering knuckles off when I did my ball joints. It works pretty good.
My favorite HF toy.
Old August 16th, 2011, 08:50
muddypunk muddypunk is offline
TOOL
Originally Posted by cherokee chuck View Post
3X, actually that's about all I have ever used mine for. I've never needed it for a TRE
lol this is my Old Man I havent found his posts on here before !
Old August 17th, 2011, 20:41
Xjcrazy57 Xjcrazy57 is offline
A big ol hammer did the trick for me today!
Old February 1st, 2019, 13:47
soyjer soyjer is offline
Originally Posted by xjtrailrider View Post
I've used those as well and broke a couple in the process.
I just removed my very rusted steering damper ball stud. I applied some cheap penetrating oil, left it overnight, then tried a normal (not hinged) TRE puller, and as I torqued it down the puller hooks actually started to separate and come off of the drag link....the ball stud was THAT rusted in place. I noticed that the Chrysler Puller tool C-3894-A called for in the service manual to do the job is a hinged puller...perhaps that keeps it from slipping off like mine did.
So I went to Autozone and got a loaner #27170 hinged puller (with two cross-bolts to prevent the hooks from separating, and a surface at the end of the screw shaft to bang on with a sledge hammer), then applied a 50/50 AFT/Acetone mixture to it, and torqued it up as far as I could without feeling as if I would damage it, then banged on it with a hammer, and the ball joint STILL wouldn't budge. However, I left the puller on there overnight, and by morning the ball stud popped out.
Old June 12th, 2019, 08:08
50/50 ATF (Dexron)/Acetone mixture, I meant.
suicide machine, need steering damper ryder Modified Tech Discussion 7 June 1st, 2006 10:53
Steering Damper heyhar OEM Tech Discussion 0 April 21st, 2006 12:21
Having problems removing steering damper wildman OEM Tech Discussion 14 July 2nd, 2005 12:53
got my steering damper off without a hammer!! phred OEM Tech Discussion 0 November 13th, 2004 23:16
What Brand of Steering Damper/Stabilizer? Silverxj2000 OEM Tech Discussion 13 July 27th, 2004 21:00
