SilverbackXJ
- CO
So i just put a 94 H.O. in my 89 I got the engine from a wrecked donor. When doing the swap i put all new everything including brass freeze plugs. i got them out while it was on the stand making sure not to hit the plug recess and to actually hit the plug. Once they were all out i hit all of the block recesses with steel wool and 320 grit sand paper. When installing the nee brass ones i coated the edges in shellac head gasket sealer and taped them in with a socket and extension making sure all were straight and perfectly seated aginst the chamfer all the way around. I even had to redo some i wasnt happy with.
At first they sealed perfectly and everything was fine ive taken it wheeling twice, driving it to and from the trail, with no problems until yesterday i noticed the first two are weeping down the side of the block. Its not bad, not enough to make a difference in the water level, but i have no water gauge right now so im really treading on thin ice right now.
Any ideas on what could cause this?
How could i drive 2000 miles them be fine and now have a problem?
Did i overheat it and that cause it?
Improper installation?
The stock sending unit for the gauge was broken off in the motor and i failed to notice until i already had it in. I shoot it with an IR thermometer every hour of driving or so and ive never seen anything over 210 at the tstat housing.
