What's the best way to remove the front stabilizer bar brackets without breaking or snapping off the bolts. If you do break a bolt, what is the best way to get the broken bolt out, or the beat way to remount the bracket.
I thought so at first too... But idk what he is talking about- the bolts for the sway bar to the unibody?? Pretty straightforward.. Soak and remove... Or maybe the sway bar links on the axle side?
I'm taking about the U shaped brackets that hold the rubber cushions that the stabilizer bar slips into. The brackets are then attached to the unibody frame channel. I didn't know that there was an opening that wold allow me to spray penetrating oil through to the threads.
Spray penetrating oil inside the frame rail onto the threads twice a day for a week. Drill access holes if necessary. If the bolts don't start to move immediately, apply heat.
