Old September 28th, 2017, 23:05
Mikep_86441 Mikep_86441 is offline
Re: Going Through a Beater XJ 4.0. Hand made gaskets.
Getting the radiator assembled should happen soon.
Lots of work to custom cut these gaskets.
https://youtu.be/nPtHTsZ8QNU
https://youtu.be/7kBaxtsCNi8
Old September 29th, 2017, 17:02
Re: Going Through a Beater XJ 4.0. Radiator Final Assembly !!
I can hardly believe the radiator was finally assembled today!! Tomorrow it gets pressure/leaked tested !!
Here are lots of details in these videos on how it went !!
https://youtu.be/Esr9hlqijcA
https://youtu.be/3DJ5TqqpSHw
Old September 29th, 2017, 17:34
blondejoncherokee's Avatar
blondejoncherokee blondejoncherokee is online now
Cool to see you put in all the work to rod it out . I hope it holds pressure ! I've always just ordered the cheap radiators, but this is cool if you have a all brass radiator and the time to do all of this !
As soon as I crest the top i'ma turn driver and floor it!
1998 4.6 stroker , aw4 XJ on 60/14b , 5.38s, grizzly/detroit, cage, 40s, psc big bore box , assist, 3 link,transgo aw4 reprogram
Old October 5th, 2017, 17:24
I pressure checked it on bench. It holds pressure nicely. Test drove it today and all is well !!
Old October 5th, 2017, 17:27
Re: Going Through a Beater XJ 4.0. Radiator Finished !!!
A test drive and over an hour of idle testing and jeep is not overheating at all !!
After a few days of driving it around, it will be time to put it in the garage for motor tear down to find the engine noise.
https://youtu.be/xUSj6ZiZjOQ
Old October 5th, 2017, 18:58
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
5/8 and 3/4 heater hose and just loose the bottle all together.
Old October 6th, 2017, 21:30
That's a great idea ! We just bought a new overflow bottle, still in the box.
Maybe even put in a later version overflow bottle in that area. I'll look it over in the morning !!!
Better still, just use the old overflow bottle as the overflow bottle for the radiator cap. The old bottle won't be pressurized so it will last. Just need to adapt it to the 3/8 overflow hose.
Old October 7th, 2017, 08:10
NAXJA Member 4950
On my 89 I removed the bracket the pressure bottle sits in and put a overflow off of a 95 there
Old October 8th, 2017, 22:16
Right! My thought was to try and plumb in the original over flow tank. Finding 3/8 rubber overflow hose seems impossible in a 6 foot length. Maybe fuel line or similar instead.
I bypassed the original tank with 5/8 hose at both ends. Pressure tested great. Saved the cost of a new tank. So thanks for that idea !!
Old October 9th, 2017, 07:25
NAXJA Member 4950
I just went into the parts store and got 6' of appropriate sized vaccum line..
Old October 11th, 2017, 17:17
All 3 stores here didn't have vacuum line either
5/16 vapor line worked ok, just pricier.
Old October 11th, 2017, 17:19
Modifying the factory overflow tank to be a no pressure version, worked out nicely. Pressure checked the system to 15 psi. Perfect !
https://youtu.be/DQsW-ha7v6k
Old October 15th, 2017, 17:13
Re: Going Through a Beater XJ 4.0. Engine tear down time.
2 days ago we took the jeep through a dry wash that was huge and deep with sand. So much fun in 4 hi !! The engines torque really showed up well in the deep sand at about 1500 rpm ! I wanted my gf to make the same drive but we never got the chance.
Yesterday the knocking sound got far worse and the engine started to miss. So we cleaned out the shop, drover her in there, and put the front end up on jack stands to let the suspension stretch down a bit. The oil pan comes off first for piston inspection.
Old October 15th, 2017, 20:18
Easy emission hose repair.
https://youtu.be/VjF9dczjwUM
Old October 20th, 2017, 20:20
Re: Going Through a Beater XJ 4.0. Oil Pan removal !!!???
I can't for the life of me get the oil pan off !!
CRC gasket remover didn't help either. I'll try another coat.
beater! ehall North Atlantic Chapter 649 November 18th, 2018 16:56
Beater XJ itrack Modified Tech Discussion 7 April 1st, 2011 10:02
Who's got a Beater Rig? Letterman Sierra Chapter 10 November 6th, 2010 12:52
My new beater hollywood32 SoCal Chapter 11 March 9th, 2007 18:34
beater? skunkman Tow Rigs and Trailers 2 October 10th, 2003 08:26
