Old March 24th, 2008, 04:40
garr garr is offline
Re: help oring filter adapter , still leaks after instaling new orings?
Originally Posted by xj2win
Soaking the O-rings in oil sounds like a horrible idea, since that's what makes the adapter leak - years of hot oil against them eventually breaks down the rubber.
<br>
OP: If you're using the correct size O-ring and tightening it down correctly, it shouldn't leak. Be sure and clean the mating surfaces while you have it apart, and I'd just go ahead and put a nice bead of high temp RTV around all the O-rings. I've taken mine apart before and couldn't find one size of the O-ring, so I just RTV'd the whole thing really good and drove it like that for about two months before I got time to fix it again, it never leaked during the time.
The 2 "O" rings mounted on the big torx bolt need to spin easily during installation, The oil makes it smoother.
Old March 24th, 2008, 08:23
FordGuy's Avatar
FordGuy FordGuy is offline
I say oil the o-rings. Every Trans class I have taken whether it was Ford, Honda, Jaguar always tells you to Lube the o-rings before install.
Old March 24th, 2008, 14:50
mramr1974's Avatar
mramr1974 mramr1974 is offline
i didnt soak the o rings thought that was a strange suggestion
Old March 24th, 2008, 15:58
mramr1974's Avatar
well i got it but also the oil preasure sending unit is leaking not where it attaches to the block its further back on the connector i guess buy a new one. thanks 4 the help
Old March 24th, 2008, 16:46
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
"further back on the connector" ??
Do you mean it's leaking where the oil filter attaches? Because those are the only two places it should leak, unless there's a crack in the actual adapter or it's coming through the adapter bolt. If it's leaking from the filter end, I seriously recommend pulling the filter and making sure you don't have two gaskets stuck there.
Jim www.yuccaman.com
Old March 25th, 2008, 03:57
mramr1974's Avatar
Smile Re: help oring filter adapter , still leaks after instaling new orings?
well id like to thank everyone turns out the opsu was bad as well which looked like the oring on the adapter was still leaking since its right above the adapter so i got a new one from parts store for 5 bucks no more leak im sure they were both leaking before so its all good now. but now my waterpump leaks after i changed the belt man what a B??ch. oh thats why its was a $350 jeep.
Old March 25th, 2008, 10:39
TiRod's Avatar
TiRod TiRod is offline
Yeah, the sender unit will leak, and since it's right above, its hard to see.
Water pump? The pump should only leak from the purge hole under the shaft. If it looks like a gasket leak, check the hoses above to make sure, but probably putting pressure on the shaft from a new belt speeded things up. The best way to check belt tension (from here) is to keep tightening it until it stops squealing. Much less likely to overdo it on a 4.0 that way.
Old November 3rd, 2008, 08:08
Rattlesnake Rattlesnake is offline
So what was the consensus on soaking the o-rings in oil prior to installing them?
I ask because I started this job on Friday, put my o-rings in some oil to soak, got stuck (pun intended) trying to get the stupid torx bolt off, then had to go out of town for the weekend and I left them soaking in oil the whole time I was gone (currently still in oil, been than way since Friday). Does anyone think this will be an issue? Any chance the oil broke them down any while they were soaking? Or should I just run by the dealer and get some more o-rings? I'm thinking they'll be fine... after all, they make contact with oil all the time once they're installed, but just wanted to consult the experts. Thanks!
Old November 3rd, 2008, 10:43
Yucca-Man's Avatar
NAXJA Member # 683
Should be fine. If you try to put them on and they're sloppy loose, then you need new ones.
Old November 3rd, 2008, 11:57
Thumbs up Re: help oring filter adapter , still leaks after instaling new orings?
Cool... thanks!
Old November 3rd, 2008, 17:51
Inklover17 Inklover17 is offline
Can you buy these at Autozone/Oreilly's?
Old November 3rd, 2008, 17:55
Shorty Shorty is offline
Gone but not forgotten...
Fel Pro doesn't list them that I can remember, but I'm not sure if Zone and O'Reilly carry them anymore. I got them at the Chryco Dealer and wasn't too unhapy with price. Seven bucks IIRC. It wasn't worth the extra effort to try to chase them down elsewhere, but it still bugs me that I paid over two bucks for each O-ring....
Old November 4th, 2008, 06:32
My local dealer let me have em for $5. Not bad, really...
Old May 1st, 2019, 19:59
mhead mhead is offline
I would like to replace the orings on the oil filter adapter on my 1992 XJ 4.0. Can anyone tell me the part numbers for these rings and where I can purchase?
Thanks!
Old May 1st, 2019, 20:35
lawsoncl lawsoncl is offline
Thanks!
https://www.partsgeek.com/f2gpc7k-je...er-o-ring.html
oil filter adapter shameless defect OEM Tech Discussion 10 June 26th, 2006 17:28
oil filter adapter scotttruhart OEM Tech Discussion 4 March 15th, 2006 19:54
4.0 Oil Filter Adapter REDSWAG OEM Tech Discussion 17 January 24th, 2006 00:15
89 4.0 leaks oil, pan, filter housing, main RangerRick OEM Tech Discussion 11 December 8th, 2004 16:17
Oil filter adapter? Jeepster4wd OEM Tech Discussion 16 February 27th, 2004 01:15
