Old August 4th, 2006, 09:32
Biglead's Avatar
Biglead Biglead is offline
Question Fuel injection problems
For a project, I purchased an 89 pioneer with really high mileage with the intention of making it in to a trail rig. Anyway the 300,000+ mile engine was replaced with a rebuilt long block from the local parts store which is working fine but I used the original fuel injection parts from the old motor. The motor has been working great for the last 10k but now I am noticing a hiss coming from the injector closest to the firewall when I start the engine on colder mornings. There are no fluids leaking from the injector and I can wiggle it to make the hiss go away. I know I need to replace them or have them rebuilt because they are pretty old. BUT I recently read a few articles on replacing the old ones with certain year Ford or later year XJ injectors and increasing the mileage a bit over stock. Something about a better spray increasing mileage and what not. Since the injectors are pretty expensive to replace I was wondering if anyone else has used other than stock replacements with any noticed improvement or am I better getting the correct ones for my make/model.
Old August 4th, 2006, 09:53
RichP's Avatar
RichP RichP is offline
Re: Fuel injection problems
I bought a set from fiveoh motor sports, replaced the stockers with them when the new jasper reman went in. Same milage...
Old August 4th, 2006, 10:19
langer1's Avatar
langer1 langer1 is offline
The hissing sound is a vacuum leak around the injector, not the injector.
You did replace the o-rings? One may have gotten nicked when you did.
Old August 4th, 2006, 14:36
Saudade's Avatar
Saudade Saudade is offline
What Langer said about the leak x2. Most likely the end that goes into the head.
I bought a set on eBay that were from a Mustang. Got a set of 8 for about $50. I haven't notice any real mileage improvement over the long term. My throttle response did seem to improve. But then, my old injectors were pretty dirty.
Old August 7th, 2006, 18:18
90cherk 90cherk is offline
From my experience when my injectors started leaking I replaced with a pulled (not new and much cheaper) Bosch set purchased from five-o motor. Ended up having to replace one of those that for some reason was sticking open. Anyway after some other engine work now my mileage has gone up about 1mpg based on my highway driving which is better than the mileage I got when it was brand new 16 1/2 years ago.
N20, Water Injection, & Fuel Cooling GoliathJeeper Jeep Street and Performance 4 April 27th, 2006 15:02
HELP!!!! fuel injection problems UrbnXj OEM Tech Discussion 5 April 10th, 2006 07:28
Aftermarket Fuel Injection Boatwrench Modified Tech Discussion 0 May 9th, 2005 20:18
F**king Fuel Injection!!!! :( olivedrabcj7 Modified Tech Discussion 18 February 4th, 2005 16:14
ford fuel injection???? Codeman Modified Tech Discussion 1 January 10th, 2004 20:47
