Old May 18th, 2019, 08:26
Rockpig Rockpig is offline
No power to starter relay?...
Complete ground up rebuild. Swapped in aw4 from ax15. No neutral safety switch no hook up, was manual trans before. Have all put back together. No crank. Checked starter relay no trigger no supply. Ignition switch operating as it should. All new good grounds and wires. 1991 4.0 xj fuel pump all works except no power to starter relay. Will turn over if starter is triggered manually small wire from starter is good to relay. Any help. Maybe clutch safety switch?
Old May 18th, 2019, 22:11
lawsoncl lawsoncl is offline
Re: No power to starter relay?...
A 1991 doesn't have a clutch switch. The manual wiring harness should be providing the ground to the starter relay, whereas the automatic wiring harness routes the ground through the neutral safety switch. I didn't need to do anything with the starter relay when I swapped my 89 from the ax15 to the aw4.
Looking at the starter relay in the PDC, the trigger coil should already be grounded and the triger voltage comes from the ignition switch. Looks like power to the contacts that feed the starter solenoid come from fuse F5 in the PDC.
Old May 19th, 2019, 10:33
Thanks, still no start but turns over with key 50 psi at fuel rail tried twice to hit but still no start will check injector signal and spark tomorrow thank you for your reply. Any other ideas?
Ignition? Starter Relay? Starter? RebelXJ OEM Tech Discussion 11 January 18th, 2012 11:03
Starter Relay? cherokee4fun OEM Tech Discussion 4 October 13th, 2008 20:16
Starter Relay??? mgreen1989xj OEM Tech Discussion 5 August 12th, 2006 09:07
90 Xj 4.0 Starter Relay 90xjpos OEM Tech Discussion 3 April 20th, 2005 19:07
troubleshooting starter relay RNMedic OEM Tech Discussion 7 June 1st, 2004 10:15
