Old May 17th, 2019, 08:23
Submariner's Avatar
Submariner Submariner is offline
Issue with a 99 xj 2dr hinge pin
My 99 2dr hinge is worn out. open the door and it drops about 1" or more. So I took it apart Had to cut it pin in half to get it out.
now for the problem. the pin is not worn but the hinge itself is worn.
So I have about .250 sloop around the pin and the hinge that is welded to the jeep.
I would post a picture but I am not allowed yet.
Any suggestions on what to do next?
Old May 17th, 2019, 08:50
RCP Phx RCP Phx is offline
Re: Issue with a 99 xj 2dr hinge pin
Easiest would be to weld up the hinge and re-drill it. I would add a bushing while I was in there.
Old May 17th, 2019, 10:10
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Locate an oversized hardened pin, then drill and ream the hinge to fit the pin. Or, fit a bushing and buy a pin to fit the bushing ID size.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old May 18th, 2019, 08:11
Submariner's Avatar
followed your advice, Drilled out the hinge part that goes on the door to fit a grade 8 bolt that has a smooth shaft that is long enough to go thru the hinge. Had it in my spare bolt can, LOL redneck. then once placed in place, I tack welded the bolt to the hinge that is welded to the body. Nice tight fit, Whne tha wears out in 10 years I will worry about how I will fix it then.
wtb: need door hinge! Brandoson Arizona For Sale/Wanted 2 May 6th, 2009 22:43
wierd hinge userbmx1315 Modified Tech Discussion 3 December 7th, 2007 20:15
New Door Hinge Brians1119 OEM Tech Discussion 2 August 7th, 2006 07:29
door hinge? TheBlueSub OEM Tech Discussion 2 November 10th, 2005 15:55
Hinge fix poolespond OEM Tech Discussion 3 January 17th, 2005 18:57
