Old May 17th, 2019, 13:38
MechanicalType MechanicalType is offline
Crank no start..
Yes sir.
Old June 4th, 2019, 14:46
Crank no start..
Finally got around to this past weekend. Fuel pump is getting full battery voltage on cranking. I jumped power to the pump to help prime it on key on and it fired right up. I shut it off and it started a few times no issues, then it started taking longer and longer. Iíve realized if I pump the pedal (i.e. carb engine style) it seems to fire over on its own after a few seconds. Without touching the throttle it wonít fire at all. Flaking TPS?
2000 xj loud noise at start of crank - no start bobhouseholder OEM Tech Discussion 28 September 1st, 2018 22:11
98 XJ crank no start tricker OEM Tech Discussion 16 January 11th, 2017 15:31
XJ No start, No Crank b_palmer22 OEM Tech Discussion 5 November 25th, 2014 10:53
Crank, No start ecgtech OEM Tech Discussion 2 October 5th, 2009 11:11
crank-crank-crank-crank-cra... [wait...] crank-crank-START! iBran OEM Tech Discussion 20 October 21st, 2005 17:33
