Old May 16th, 2019, 14:58
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
Re: Tire recomendations for stock Daily Driver?
I run Firestone Destination AT on mine in the factory tire size with favorable winter traction results this past winter. Being all terrain they may be a little louder.in the road noise department, but I find it tolerable.
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Old May 16th, 2019, 15:53
TRCM's Avatar
TRCM TRCM is offline
For a stock rig that is mostly a daily driver, I've had very good luck with these.......and they do pretty darn good in mud & snow/ice too.
I had them on a 7500 lb dually and they never had a single complaint. Wait, only complaint is they do seem to pick up and sling small rocks if you drive on gravel roads a lot.
https://www.tirerack.com/tires/tires...A% 2FT+Revo+2
Old May 16th, 2019, 16:03
RCP Phx RCP Phx is offline
That tire isn't available in his size either. Best bet, search by tire size and see what you come up with!
Old May 16th, 2019, 16:04
md21722 md21722 is offline
I replace my tires when I cannot drive through a torrential downpour without slowing down.
My 01 XJ is stock and has run BFG AT 235/75R15 for the last 372,000 miles. I have gotten as much as 90,000 miles out of them with lots of highway miles. By then the rubber gets stiffer and braking distance is longer and they start to feel torrential rain. They are heavier and with stiffer sidewalls than say Goodyear Wranglers, but ride well (maybe somewhat noisier after a few rotations). The last time I had a problem with wheel balance was about 10 years ago. I have never had a flat tire with one. have broken belts on some less than desirable stretches of I-40 on lesser tires, but never with these. They are pretty much indestructible for road use, plus they have a Snow Rating.
Goodyear Wranglers I'm trying are lighter and have softer sidewalls. Tire shops seems to need to balance them all the time to keep them from vibrating the steering wheel at interstate speeds. I have actually had 'minor' death wobble where I'd have to pull onto the shoulder and slow to 40mph because they were out of balance and starting violently shaking the steering wheel until I slowed down.
I have run the Bridgestone Revo's on trucks before and they are fine. I just prefer the BFG.
Old May 16th, 2019, 16:08
TRCM's Avatar
Heck, it ain't even available in the sizes I use to run anymore either......
Tire opinions for a daily driver in Colorado? SolarBell Colorado Chapter 23 November 28th, 2011 08:26
Daily Driver: Best Lift Height and Tire Size Combo for Weekend Fun Quills Modified Tech Discussion 8 May 14th, 2008 14:09
Good All Season Daily Driver Tire Recommendation? JoshRountree OEM Tech Discussion 43 December 25th, 2007 05:52
Tire recomendations... themangeraaad Modified Tech Discussion 33 April 19th, 2006 19:38
Tire size for a daily driver.....? Fogman Modified Tech Discussion 23 September 4th, 2003 20:30
